I want to disconnect My Freeze - Computers & Internet
    Sergeant:
  • 201 Answers
Hi you need to uninstall this program from add and remove in your control panel.
Posted on Aug 24, 2010
Intermatic t1202T 240v dual pool timer. Main pump continues to run and manual overide will not shut it off. Changed the timer mechanisim and same thing. Disconnected the Freeze control and it wil
Maybe the PF1202?
Probably just the freeze thermostat and not the relay.
Disconnect freeze thermostat wires from relay... and substitute a single-pole switch.
Be careful... power is ON
http://waterheatertimer.org/Intermatic-freeze-controls-and-parts.html#1202
http://www.amazon.com/dp/B003Y5EY6E/?tag=waterheaterti-20
http://waterheatertimer.org/images/178T24-thermostat-wiring.jpg
http://www.amazon.com/dp/B003P52CKS/?tag=waterheaterti-20
Do not leave the single-pole switch connected since 15 amp rating of typical switch is less than amp rating for 40 amp pool centers
Gene
Jun 01, 2014 | Intermatic & Indoor/Outdoor Rain Tight...
Skylanders swap force game keeps freezing?
if you're running into a freeze on your PS3, just let us know which Skylander you're using, along with when the freeze occurs for you.
If you can, try disconnecting your PS3 from the internet when it freezes then reconnect
Oct 19, 2013 | Skylanders SWAP Force Starter Pack
Freeze plug replacing
You are pretty brave lady at 64 to attempt replacing a freeze plug.
Is the engine V6 type crosswise mounted? Then the location of the plug would not be easiest to work on. Do you absolutely hae to replace it? Is it corroded to the point where it leaks coolant through a pinhole? You would need to drain the coolant first by disconnecting the lowest located hose, that carries coolant in/out the radiator. It is to be done on a cool engine, of course, to be safe. Remove radiator cap after disconnecting the hose to promote the flow. You have to catch the draining fluid into a pan to reuse later, if possible, or replace the fluid afterwards. Unfortunately for this task there is no easy way... Otherwise feel free to ask more... God bless you.
Jul 23, 2013 | 2005 Pontiac Grand Am
Will my intex pool pump & hoses freeze overnight?
All you have to do is run the pump during the hours a freeze is expected. A light freeze usually won't cause damage, but to be safe run the pump at night
Mar 02, 2013 | Intex Pool & Spa
How to winterize the h100id1 hayward pool heater
disconnect or blow out with air and antifreeze then pull freeze plugs and disconnect pressure switch and turn off gas
Sep 23, 2012 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Pump continues to run constantly after freeze protection was engaged. The temperature is now over 70 degrees F but the pump will not turn off unless you flip the override switch on the outside of the...
The freeze protection thermostat has gone bad.
To confirm this, disconnect wiring from freeze control.
Freeze control can be purchased separately.
Search: Intermatic Freeze Protector
For example, Smarthome:
http://www.smarthome.com/42697/Intermatic-PF1102M-240V-Freeze-Protection-Control-Timer-Mechanism/p.aspx
I am familiar with wiring for Intermatic pool controls.
If you have problem, add a comment with exact model number or photo of product.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Also if you re-post question another question at Fixya with exact model number, I will probably see it.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call
Feb 21, 2011 | Intermatic PF1202T - Pool-Spa Freeze...
Drain washer pump for winter
Turn off the water at the cold and hot taps. Disconnect the hoses from the taps and the washer and drain them. Lay the drain hose flat on the floor to drain it to a container. With the hoses disconnected and the drain hose flat, start the fill cycle (set to WARM) briefly (15 seconds) to open the inlet solenoid valves and allow water to drain from them. Start the rinse cycle to pump any residual water out of the tub and drain (15 seconds).
OR
Turn off water and disconnect inlet hoses as described above. Pour 1 gallon of RV anti-freeze (for potable water systems) into the tub. Start the rinse cycle just enough to start the drain so antifreeze goes through pump and into drain hose. Before using the washer again, run a small rinse through to flush out the anti-freeze.
Nov 11, 2009 | Office Equipment & Supplies
My i pod wheel has frozen. None of the buttons work on my Ipod only the hold button when it is slides across causing the screen to light up. The i pod is 60gb and has not been dropped or exposed to...
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
That should get rid of the freeze.
If your unproperly disconnecting the ipod from your computer before the itunes
sofware disconnects it for you, then that could be your problem with the freeze ups.
Oct 23, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
