Question about Bausch and Lomb Bausch & Lomb Hunting Elite 4200 Riflescopes Matte Finish With Sunshade Pow
When I look through my scope I can't ever get into focus. I have other people look through it also with the same results. The scope fogs up now in cold weather also
    President:
  • 2,702 Answers
There is an air leak on this scope and bamp air has got inside it,,all you can do is strip the scope out clean all the lenses and re-gas it,,,,to be honest,,,its a bust bin job now!
Posted on Aug 25, 2010
I have a zeiss diavari 3-12x56 which has fogged up with water ingress after about 4 years on the rifle. I would have expected more from a so called high end scope. Any one else had a similar problem. ...
I would be persistent with Zeiss' customer service. Usually, high end companies will stand behind their product and make it right, provided that the problem didn't result from outright abuse.
Jul 11, 2011 | Zeiss Riflescopes Victory 312x56 T Diavari...
Scope is a 1995 year model. Optics got blurry this season.
could be the the eye sight adjustment piece at the front of the scope got turned some how , try turning the lens piece to focus ... If it looks like fog , it is probably the nitrogen has leaked out, you will have to return it for repair..
Dec 30, 2010 | Tasco World Class Rifle Scope 3-9x50 Matte
Using the scope
Well if it was a rifle, I would say far away, or you will get a black eye. But the recoil on a pellet rifle is backwards because the spring jerks the rifle forward, and it messes with rifle scopes, they are made to recoil back, But,,, you have a movable eyepiece in the end where you look through and it will make the cross hairs come into focus for your eyes. some one else might find them blurry. The objective lens, should be in focus no matter what. It doesn't move. and no matter what your vision is, you should be able to see clearly. If not, I'm wondering if it is fogged up. Your eye should be about 3inches, + -, Check it out. Hope this helps.
May 04, 2010 | Crosman 4 x 32 Air Rifle Scope, Black
Fogging up all time
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trash can size. You will need to get your hands on some nitrogen gas or you can also use carbon dioxide - even try nitrous oxide it should be easy to find at a sports store for paint ball guns . You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it sit and dry out. Now check for any o-rings and try to find new if you can, put the grease on the screw threads at the end of the scope. Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Feb 07, 2010 | Optics
Scope is fogging up
Either use an anti-fog wipe on it, such as Scope Dope... or don't breathe heavily on your lenses!
Jan 01, 2010 | Tasco Hunting World Class Scopes Standard...
My scope is fogging up on the inner lense not outer lense
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trash can size. You will need to get your hands on some nitrogen gas or you can also use carbon dioxide gas. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off of your scope, (This means unscrew it from the scope body) let it dry out a day or so. Now ck for any o-rings on the scope body some will have a small o-ring - like a good flash light the good metal kind, and try to find new if it has one if you can, put the grease on the screw threads. Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Dec 11, 2009 | Bushnell ® Elite® 3200 3 - 9x40 mm...
Rifle scope fogging
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trashed can size. You will need to get your hands on some nitrogen or you can also use carbon dioxide. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads.Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Dec 03, 2009 | Optics
Got moisture in scope and it is fogged up
take it into a camera shop, they will have the tool,, but if you undo the scope it will need to be regased again the "o"ring seals have worn out or broken and thats how water got into it,, it also let the nitrogen out of it,,,if its a cheepy scope buy a new one,,,
what i mean by a cheepy is less than £1000,,,,
Nov 16, 2009 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Fogged up
What is happening is, when the scoped hunting firearm is stored inside the night before the hunt and its warm inside the house and when you go outside in the cold, the scope fogs up. Much like someone who wears glasses, when they are inside a warm house and they go out in the cold, their glasses fog up. The way to prevent this is to store the gun outside the night before the hunt where it's still secured but cool like the outside. Lock it in the trunk of your car or a locked tool box in your truck. In this way, the scoped hunting firearm will be about the same temperature as the cool outside air and it will not fog.
Aug 20, 2009 | Optics
Scope fogged up on the inside and i cant see out of it. while hunting in the winter the scope fogged up. now that it is getting warm out it cleared up.
The gas inside the scope has leaked out. Moisture condenses in the cold weather and fogs up your optics when this happens. Send the scope to the manufacturer and they will warranty it. All scope manufacturers have real good competitive warranties. TP
Apr 16, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
Bausch and Lomb Bausch & Lomb Hunting Elite 4200 Riflescopes Matte Finish With Sunshade Pow Logo
111 people viewed this question
Top Bausch and Lomb Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Piyal Perera
Piyal Perera
Andrew Taylor
Andrew Taylor
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
