I have got myself a pesario v6500 from a friend- (reasonably new computer) they said that they left it on a bed overnight and have fried the harddrive- ( after taking it to PC world they said the hardrive was fired) i have bought a new 320 gb drive and replaced it (quite easy process) i cant get the computer to switch on- i have the blue power light at the source plug but thats it?? help.. otherwise i've just wasted 70 quid..!!
  • kate_hignett Aug 25, 2010
    tried that already... re below comment fromn Juan-= still does not switch on.???
    Sergeant:
  • 235 Answers
Remove the hard drive and try to turn on the computer. If it turns on (of course it's not going to boot) try to go to the setup screen. If that works then you either have a bad drive or it is not installed properly. Have fun!
Posted on Aug 24, 2010
  • Juan Perez
    Juan Perez Aug 25, 2010
    OK, If it is not coming up at all then maybe your old hard drive is still ok. Try, removing the battery and turn it on with just the ac adapter plugged in. If it works, then your battery is bad. If it does not come one then try a different ac adapter from Radio Shack, a local PC Shop, or any electronics store. If it still does not work then more than likely it is your dc jack. The dc jack is not that expensive, you can get one online but to replace it you have to take the computer apart and do some soldering. Find out how on Youtube or get a local tech to do it for you. Good Luck and let me know.
Brake line leaks above the gas tank-is there any easy way to fix this
Easy? No. Easier, yes. Remove truck bed bolts (~4-6, not hard to remove), raise bed by blocking bed up with 4x4 or 6x6 wood blocks. Access brake lines, fuel pump, etc. I lifted mine by myself to replace a fuel pump. I may have learned about tip on fixya long ago myself.
Oct 09, 2013 | Chevrolet 1500 Cars & Trucks
My hp compaq Presario V6500 has been damaged and a computer dude in Bathurst NSW said we need a bulb replaced in the screen as it won't light up. Computer functions via TV. R there any local repairers for...
The monitor screen on your laptop is an LCD screen.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
The additional light source is a Backlight.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
LCD screens are a composite of layers. The layers are held together by a metal frame, much like a picture frame.
The Backlight is usually located on one side, accessed after removing one side of the metal frame.
As stated, a Backlight is a very small type of Fluorescent lamp, (Tube)
Very fragile, easily breakable, and not usually approached by one who has very little, or no experience in replacing.
More common the entire LCD screen is replaced, which includes the Backlight already installed.
A laptop also needs an Inverter to provide power, both for the LCD screen, and the Backlight.
90 percent of the time the fault is the Inverter.
I repeat, 90 percent of the time the fault is a bad Inverter.
An Inverter is cheaper than an LCD screen, and MUCH easier to replace than a Backlight.
Allow me to show you replacing an Inverter on an HP Pavilion dv6000 series laptop.
Granted, it isn't an HP Compaq Presario V6500 series, but the principles still apply the same,
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
I can also provide a free link, to the Service Manual for an HP Compaq Presario V6500 laptop, direct from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3369429&
In the list click on;
Compaq Presario V6500, V6600, and V6700 Notebook PCs-Maintenance and Service Guide
This is a PDF file.
Allow up to 30 seconds to see the first page, and an additional time may be needed to fully download.
In the Bookmarks menu on the left click on the + sign next to;
1) Removal and replacement procedures
2) Component and replacement procedures
3) Display assembly
And/or go directly to Page 61 to view the Inverter location.
One example of an Inverter for an HP Compaq Presario V6500,
http://www.sparepartswarehouse.com/Compaq,Presario,V6500,Laptop,Inverters.aspx
Granted this is not what you asked for.
My premise is to teach, and hopefully save people money.
If you have additional questions please state in a Comment.
Regards,
joecoolvette
Mar 06, 2011 | Compaq 449901-001 - HP Presario V6500...
2010 Ford fusion I left the parking lights on overnight and find battery dead the next morning. I charged battery overnight, but still could not start engine. When key is turned it displays the battery...
Well contact your dealer and tell them that your battery is gone bad for no reason and don't mention you let the light overnight because your battery is under warranty and they will put in a new one. Good luck
Jan 09, 2011 | 2009 Ford Fusion
When I try to power on my compaq pesario f700 laptop the light just flashes once and nothing happens I assume its the power supply of the laptop can I replace this myself I am very Tech savy and have...
Remove your battery and try with external power supply again if it boots up all good and proper then after booting to SOE refitt the battery and let it charge - if it doesn't boot or power on look to see if the blue LED it on around your power input point. If there is no illumination around the power input port try another 65w power supply input - your power pack may be dead. Cheap fix - if it still does the same powers on then off - you have reason to go out and buy a new laptop - would be cheaper than replacing the M/board
trust me.
Jun 17, 2010 | Compaq Presario Notebook
Nintendo ds lite, Got damp. Worked iinitailly,
well yes the battery is pretty much fried but you can get a new battery online from nintendo
Aug 03, 2009 | Nintendo DS Console
A repairman said the motherboard was shot
Yes all motherboards are replaceable, Your just going to have to find the correct part # you need. The motherboard shouldn't run you more than 100$, although a repair shop will charge upwards of 300-400$ for the time to install.
May 27, 2009 | HP Compaq Motherboard
Video and lan driver for compaq v6500
i need all drivers of compaq presario v6500.. pls... help me!!!!! thanx
Jan 30, 2009 | Compaq Deskpro EN 6500+ Model 6400 CDS PC...
Ipod 5th gen issues
Tough call on this one as it could be that a motherboard component was fried. Have you tried to do a soft reset on the unit by pressing the menu and center buttons at the same time for 5-7 seconds? Believe it or not, sometimes that resolves the issue.
The other option is to get us your unit for our FREE Diagnostic Testing. We will inspect the unit on our test bench, provide you with a repair estimate as well as a recycle price in which case we would buy your broken iPod from you for recycling.
Regards,
Rick
EverGreen Electronics
'Eco-Friendly iPod Service, Sales & Recycling'
E-Mail: sales@evergreenelectronics.com
Website: http://www.EverGreenElectronics.com
FREE Apple iPod Technical Support - http://www.iRepairGuide.com
Jun 06, 2008 | Apple iPod MA446LL/A MP3 Player
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
