Hi and thanks for reading this. I have recently had a complete house overall, included a new bathroom. Part of this included getting an electric shower which I was advised was very powerful. Anyway it seemed to be working for the first 3 days of use (not pumping powerful but a reasonable flow of water coming from the shower) however the during this time the temperature adjuster knob would not turn anti clockwise (cold) and only clockwise to hot. on the fourth and every day since (been using it for nearly two weeks now) the shower stops and starts combined with very low flow, goes very cold and very hot, the knob now turns clockwise and anti clockwise however this has no impact on the temperature. I have told the plumber about this but he keeps saying that these are top of the range showers. What do I do? Who is accountable? I look forward to hearing any advice available. Thanks Carol
  • 107 Answers
I would go to the supplier or Manufacture to know who the certified rep is in the area and use them and back charge plumber...
Posted on Aug 25, 2010
I need help finding a ecu pin out diagram for 2003 toyota celica gts
You will have to read several diagrams for the complete pinout. The disgrams are available at autozone.com.
Sep 14, 2017 | Toyota Celica Cars & Trucks
I want to turn off my electric underfloor bathroom heating completely and don't know how.
There should be a fuse or breaker that would turn that off. It should be on one circuit by its self for the bathroom heating system. If its a breaker just flip the breaker switch.
Apr 21, 2015 | Electric Hardware & Accessories
Why do i get power at the 120v outlet but nothing works when its plugged into the outlet
It sounds like a bad neutral wire. Somewhere the neutral is not properly connected. Most residential wiring operates on a 240 single phase system comprised of two seperate 120 volt legs. Connect between either leg to the neutral gives you 120 volts.connect btween the two legs gives you 240 volts. If the neutral is not present the circuit will search out the other leg to try to complete the circuit causing dimming of lights extremely bright lights and all around chaos. Check ahead of the main to see that the voltage is correct. Check each leg to neutral with a voltage tester. Have some one turn some lights on and off while checking as sometimes a load is required to get fluctuating readings. If the reading fluctuate wildly the problem is between the power grid and the panel. If not recheck on a a couple of breakers and if the readings fluctuate it is on your side of the system.
. Hope this helps
. Bob
Nov 21, 2011 | CUTLER HAMMER BR4040B200V BREAKER CIRCUIT...
My Marley extractor fan in the bathroom has stopped working, how to investigate the problem and find a fix
Chances are the motor has burned out. Fans are quite cheap and not worth repairing.
In the UK you can get a complete replacement fan from Screwfix for under £20.
Turn off electricity at consumer unit and remove fuse / turn circuit breaker to off.
Undo screw and remove front cover from the fan. Carefully disconnect wires, remove fixing screws.
Follow instructions included with new fan
Feb 21, 2011 | Home
I recently had a fan installed in a small bathroom (5x8). The mirror and windows still fog up even when I take a brief shower. A few minutes after the water stops running, the moisture does seem to clear...
On the assumption that your bathroom is 8 ft high, then the volume of air in the bathroom is 5x8x8 or 320 cu ft. Even if your fan is 80 cfm it would take 4 minutes to completely exchange the air. Leaving the door slightly ajar would assist.
To overcome a similar problem, I installed a second fan with a push button 10 minute timer so the fan runs for a few minutes after I leave the bathroom.
Sep 24, 2009 | Dryers
Replace motor in Broan 678 bathroom fan
I ran into the same problem, Lowe's carries Broan exhaust vents. They had both a replacement motor for all generations of 678 fans for $18, and they also had the latest generation of the complete unit for $40. I bought the complete unit, which included the fan I needed. Just unbolted it from the new bracket and bolted it to the old one. The new light housing, trim piece, and lens also interchanged. The existing one was old and yellowed, so this made for a huge improvement. All done from in the living space as well.
Aug 11, 2009 | Broan-NuTone N-8663RP Combination Light...
New shower installed doesnot always kick pump in
some times if there not enough water flow passing through the pump it wont kick in make shure all other taps ar off an try that ,have you got a good water pressure in you house?
Jan 26, 2009 | Home
Blown breaker
It sound like all of those go through your bathroom GFCI. I would recommend moving your outdoor circuit breaker indoors if possible or enclosing it to make it water-proof. You may also do some rewiring from your main breaker box ( if you are handy) to eliminate the outdoor box completely considering you have 100 amp / 200 amp breaker box inside your house. If you still have an old FUSE BOX with 60 amp service, I would recommend replacing it with a 100 amp or 200 amp breaker box depending on the size of your house. I would separate the laundry room by itself with 12/2 gauge wire with ground on a 20 amp breaker. You can then take your bathroom (using 12/2 gauge wire with ground keeping your gfci ) and run it to another breaker in the house with a 20 amp breaker or add a new one if there is room in your main box. Now all you have left is the porch light. You can run that separate from everything to your main breaker box using 14/2 gauge with ground to a breaker in your main box by adding a new 15 amp breaker or adding it to another 15 amp breaker that does not have a very high load such as a bedroom. In general Kitchens, Bathrooms, Laundry rooms should be on there own separate 20 amp breakers. Most every other room can be 14/2 with ground on a 15 amp breaker... hope this helps....Joe
Dec 17, 2008 | Prime 10 Amp Circuit Breaker
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
