Question about Hilti Drills
Why is there an extra wire on one brush and not on the other
    Scholar:
  • Hilti Expert
  • 123 Answers
That extra wire goes to the flashing light indicator that your have appox 20 hrs before the brushes cut out.
Posted on Aug 26, 2010
I took my radio out of my 2004 Saturn l300 and my dash light's went out there are a few extra wires behind my radio what do I do
check the fuse--you probably brushed the 'hot' wire against a metal bracket and shorted the circuit and blew that fuse.
Apr 03, 2015 | 2004 Saturn L300
The brushes are not located in the usual place at top of machine could you tell me how to locate them. We have an aquarius extra wma40
The motor is now located at the bottom rear of washer.
To access same, remove lower rear panel of washer.
You will see the motor.
Remove drive belt, and undo 2 bolts securing motor to drum.
Remove motor plug and earth wire, lever motor away from supports, and remove same. You will now be able to access the brushes.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint WMA40 Front Load Washer
Washer won't do anything. was washing a large comforter and the washer stopped working in the middle of a spin cycle. water did drain. now won't turn back on...no noise or anything. fairly new washer only...
If there is any voltage on the power group, try it temporarily with another device, if there is a control light on the display and it burned then read this suggestion.#
Its written by Hitachi but its on all kind of brushes made by other brands to find .
Carbon brushes are one of the most commonly replaced power tool parts. This is because carbon brushes are wear items, meaning that through friction and use they will gradually wear away until they need replacing. Worn brushes are a common causes of intermittent motor function, reduced electric braking and reduced motor power. A worn-out brush will often be worn down near to the wire lead and can be cracked, pitted, or burned. When replacing carbon brushes, be sure to inspect your armature for burns, cracks, or other damage which can indicate larger motor problems. [ NOW COMES THE IMPORTANT THING what i suggest ]
This Brush will pop out a pin when the Brush wears to a certain length.
It is advised to keep an extra set of these brushes on hand at all times
Jun 30, 2017 | Maytag Washing Machines
Husky 5000 watt brand has no power output
Check for a broken engine to alternator coupling. If ok, you will need a wiring diagram for the alternator. Do a web search for same.
Oct 12, 2009 | Electrical Supplies
Locating carbon brushes on a wma46 aqarious extra
the brushes at at either side of the motor, they will be about 4cm long with wires attached to them.
Apr 13, 2009 | Hotpoint WMA46 Front Load Washer
Hotpoint ultima extra wma64
hiya
check the wires which run from the motor up to the main pcb, it's quite common for these to rub together and break. i have came across this a number of times now.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drills Logo
32 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
