Question about Poulan Pro 22inch 625 Series Briggs Stratton Gas Powered Side DischargeMulch Front Wheel Drive SelfPropelled Lawn Mower With High Rear Wheels PR625Y22SHP
This is a pull start self propelled, it will start like gang busters, then quit almost immediately. I've tried new gas, and adding water evaporator / line defroster. No luck.
  • 183 Answers
There is some sort of blockage in your carb. You will need to remove the sediment bowl from the bottom of the carb. Clean out the bowl. The brass nut that hold the bowl on, is actually a jet. Clean it very well with a spray solvent. Reassemble and test.
Posted on Aug 24, 2010
Whats' wrong with Briggs & stratton self propelled lawn mower, it will not start?
Anon try putting a new spark plug in first. If still no joy come back to us.
Aug 09, 2014 | Garden
Mountfield RY150 the self propelling arm missing
You can try http://www.jungle-busters.co.uk/Lawn-Mower-Spares/Mountfield-GGP-Spare-Parts
I have gotten hard to find parts from them in the past and they do carry stuff for the mountfield machines
Dec 05, 2013 | Garden
New self propelled front wheel drive mower quit running and you can not pull start rope, it has gas & oil & spark plug is connected and we are holding blade control (gas) handle back
seized up take out plug pour oil in cylinder then hold up blade brake on it side work blade back and forth till it frees up and pull with the rope a couple of times then put plug back in then start it
Jul 30, 2013 | Garden
21" Troy Built Self Propelled lawnmower engine won't start.
Remove spark plug, clean or replace. Remove air cleaner, clean or replace. Ensure oil is full. 30w. Drain old gas out of tank. Fill with fresh gas with Stabile added. Remove bowl from bottom of carb. clean. Observe bowl screw, see if hole goes thru screw. Clean out. Bread wrapper works nice. Observe float. Float down gas flow, float up no gas flow. Re-assemble, prime 3 times, pull rope 10 times to start. No start replace carb.
My cub cadet model 12A-18M7010 will not start. It has an automatic choke. No primer. I've changed the gas, checked the plug, cleaned the carbuerator. What could it be?
Also check the air filter. Some times if the paper filter is wet or clogged it will choke out the machine by not allowing air in to the ignition chamber.
Apr 17, 2013 | Cub Cadet Garden
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
I have a brand new TB250 21" self propelled mower with the Honda engine. I put it together, added oil, added gas, and when I go to start it it does not start. The issue is that I cant seem to get the...
Hi jb--
Since you have already added oil and gas, and this is a new mower, see if you can locate the 'dead man' switch on the mower. There should be a handle on the mower that must be held down when you try to start the mower. It will follow the shape of the larger handles, just about a third of the size: you can see it in the picture you used for this post. Attached to it is usually a cable that actuates a braking mechanism that will stop the mower's flywheel from turning. This handle will swing down against the handlebars of your mower before and then during normal operation. Try holding this safety down and try to pull again.
--Hope this helps.
Oct 08, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troybilt riding mower quits after 3-5 minutes of running. I can restart it but it then dies immediately. Suggestions?
remove the carberator bowl nut on the bottom side of the carb and empty out the gas from float then just put it back together there is debree or water in the float bowl.
Jul 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
After 1 season it ran great ,slowly died now it wont start
So many possibilities, so little data... <grin>
When you say "clean gas", do you mean that you added "fresh" gas, or that you emptied the tank, and refilled it with "fresh" gas?
Try this:
a. remove the "float bowl" screw, and put a regular "bowl" or pan underneath to catch ALL of the gas as it comes out.
b. if the gas is totally "clear", then it (probably ain't the gas), but... if it's "yellow", it's old and/or contaminated; alternatively, if there's any water (which may appear as a grey-ish liquid) then it's contaminated; also, don't forget to check the gas from your "storage" can, the same way...
c. re-install the the screw, and put some *FRESH* gas in the tank.
d. pull the spark-plug, and clean (or replace) it.
e. prime it, and crank it, and it should start right up.
Jul 03, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Poulan Pro 22inch 625 Series Briggs  Stratton Gas Powered Side DischargeMulch Front Wheel Drive SelfPropelled Lawn Mower With High Rear Wheels PR625Y22SHP Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
