Question about Oki Electric Industry B410D Laser 30PPM 2400X600DPI USB 32MB Dupl PCL5E 120V Printer
I have a OKI B6500, in the display: "maintenance required", i change the Fuser, and the error donĀ“t dissapear What can i do?
4 Suggested Answers
markzbylut
  • 64 Answers
SOURCE: I have a Oki b6500. Replaced the fuser. How to
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
Posted on May 20, 2010
SOURCE: Oki b2540mfp fuser error. Is there a reset in
replace main board...thats what i had to do...
Posted on Apr 15, 2010
canontech
  • 1219 Answers
SOURCE: I have a OKI C6150 got a jam now I have a Fatal #980
Inside fixing unit are also thermoswitch and thermistor wich can burn out, but also the fixing lamp too. You must dissasemble it and by DVM test the circuits, if the circuit is opend on thermistor, that means that he is burnd out.
Posted on Jul 08, 2010
How fix oki B6500 loading display error
gravity reset. seriously, hold it about 9" off the floor and drop it evenly. repeat if not fixed. this was in an oki tech bulletin. there is a ribbon cable deep inside that comes unseated. unless you want to take the ENTIRE printer apart perform the steps above. :)
Aug 19, 2014 | OKI Office Equipment & Supplies
Impresora oki b6500
oki b6500 code flash error firmware upgrade que puedo hacer
Jan 15, 2014 | OKI B6500 Led Printer
OKI B6500 service error 03
hola buenos días tengo una impresora oki B6500 se le cambio el tonner despues del cambio manda el mensaje de tonner bajo que debo de hacer para quiatar el error que marca
Sep 29, 2010 | OKI B6500 Led Printer
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
May 19, 2010 | OKI B6500 Led Printer
Service error 02
SE 02
: Software Exception
Jan 12, 2010 | OKI B6500 Led Printer
Oki Electric Industry B410D Laser 30PPM 2400X600DPI USB 32MB Dupl PCL5E 120V Printer Logo
1,204 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Tony
Roger Binsfeld
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
