Question about LG 24.7 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Titanium
What are the factory suggested settings? - LG 24.7 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Titanium
  • 86 Answers
Half way between off and the coldest setting on the t-stat.
Your refrigerator should be from 36f-40f and the freezer should be around 5f-10f. I hope this helps you. Please leave feedback.
Thank you.
Posted on Aug 24, 2010
Had blinking red light, replaced power board, same problem, replace the siene board, excellent picture but ,nosound. Returned to factory settings, no joy.
The audio is getting to the speakers from the AV terminal board. I would suggest to check the audio settings on your TV even after doing factory settings.
Sep 01, 2015 | Toshiba 42HL196 42 in. LCD HDTV
Start up disk for aspire 5336
Whoa. yOU TRIED TO do what? Oh boy, now you\'re in a pickle. My suggestion to you would be to try the Factory restore again, and THIS time have it erase the previous operating system and not SAVE any settings or ANYTHING. SOmetimes, as with ACER, and WITH ACER....Doing a Factory Restore when trying to save your OLD data will corrupt the new install 70 percent of the time. My suggestion and my STRONG suggestion is to do the Factory Restore and to WIPE out the old data and let the Acer Recovery Manager walk you through the rest. The Restore Partition has ALL of the drivers and things that you will need to get the Laptop back up and running again.
Mar 25, 2014 | Acer Aspire 5336-2524 Intel Celeron 900...
Factory reset for Craig 7inch netbook CLP281x how to factory reset laptop restore
On your craig netbook can be resetted or restored to factory settings by following the below steps in order for you to perform the process correctly:
1. power down the device
2. turn back on the net book
3. press f2 at the boot menu
4. select the option to restore your device to factory settings.
Jun 11, 2013 | Computers & Internet
Unable to restore laptop to factory setting
You didn't provide much info. Is the System restore turn on? Do you have a Factory Recovery Partition? What is the Model and OS of the Fujitsu? You can tun-up the Laptop, using some freeware software. If you provide the OS you are using, I can suggest some tips.
Mar 05, 2013 | Fujitsu Siemens Computers & Internet
I NEED TO RE-adjust the hi low pressure settings.
There are many different brands of pressure switch each having a different configeration as to setting. I would suggest to look under the switch cover for instructions or model mumber, then google for instructions for that particular model. I generally find that adjustment does not solve the problem (if you are trying to correct a problem). Example: Compressor never reaches cut-out pressure (problem with pump/cylinder/valves). Compressor set at 200psi cut-out from the factory and you would like to lower to say 125. Regulator no longer works so you need to lower pressure. If you post your exact issue, I may be able to suggest a long term solution. If your compressor is several years old, I would suggest replacing the switch with new in the pressure range desired. It has been my experience that once you change the settings from factory, the switch usually never works correctly because the factory uses different springs to achieve settings and use adjustment to fine tune + - few lbs. Good luck with your repair project.
Jun 10, 2012 | Air Tools & Compressors
I cannot factor restore my msi l1350d as the environment is stable. what does that mean
hi
it refers to factory resetting . because the system is running acceptably well, it does not require factory restoration (format and re isntalling operating system to origonal setting when it was purchased.) Is there a reason why you wish to restory factory settings ? i strongly suggest you creat boot CD set before you do anything like this .
Feb 05, 2012 | MSI Wind L1350D1672US 10 Black Netbook
Was in the middle of restoring the computer to factory settings, it was at 98% and it died now it says the windows failed to start
Hi there!
If the restoration to the factory settings did not finish then Windows was not reinstalled properly in your computer. I suggest that you reset again the computer to factory settings. If the restoration died again at any point before completion, I suggest to do a manual re-installation of Windows.
Hope this helps.
May 20, 2011 | Computers & Internet
I have a packard bell imedia mc 1538 and need to resore to factory settings, have tried using F10 key with no result just goes to start up. The master cd just does a system restore and not the factory...
If the file that holds the factory settings is gone then there is no way to restore the factory settings back. You can however reinstall windows if you got a hold of a windows disc in the version you want. You can use the windows key on the computer somewhere to activate the windows. I would suggest doing a system restore the the last restore point and removing any unwanted things from there.
May 11, 2011 | Computers & Internet
Veg./ meat drawer items are freezing? Thermostat are set at factory suggested settings. What can we do to solve the problem?
factory suggested setting are just that "suggested" turn your thermostat down to a lower number, turn it down just one notch and see if tht solves the problem, if stuff still freezes, turn it down (lower number) more.
Mar 19, 2011 | Refrigerators
LG 24.7 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Titanium Logo
138 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
