Question about Canon PowerShot S20 Digital Camera
I just purchased and utilized a brand new CF Card for my Canon S20 and I get an :"CF Error" readout. What is happening and how can I correct it.
  • 3 more comments
  • actionj89 Aug 24, 2010
    Thank you for your response. How do I do that. Format?
    How do I format my CF Card
    How do I format my CF CArd?
    Cf Read out says error- Brand new card- Someone said something about formatting?
  • actionj89 Aug 25, 2010
    Thank You!! All is well!!!
    God bless!
  • 104 Answers
The card needs to be formatted in your camera
Posted on Aug 24, 2010
  • Doug Olmstead
    Doug Olmstead Aug 25, 2010
    Note: this model will not support formatting or editing from another camera or application
    also it is advised not to remove or turn camera off while CF is being read/written or formatted.
    steps :
    1. turn camera on battery fully charged
    2. turn dial mode to camera picture
    3. press menu button
    4. use arrow button to select the tools icon (wrench & hammer)
    5. navigate down to format
    6. exit setup
    7. test camera function.
    If this does not work the logic circuits of CF card may be faulty
  • Canon Master
  • 4,924 Answers
This may be caused by the fact that you did not format the card into the camera ...For to do that ..just get into the main menu ...and look for storage ..in there select the card ..and than format it ..also select the storage to be on the card and not on the internal memory ..
If you can not find the feature in the camera ..just consult the manual for formatting card ..or insert it in a card reader in the laptop or so ..and format it in the computer ..by right click on the removable device in the my compute folder and choose format ..To format it proper ..choose quick ..and the Fat 32 mode..
after that will work in the camera ..
Remember if you can ..try to format it into the camera ..cause it is the best choice ..
Posted on Aug 25, 2010
  • Catalin Turcu
    Catalin Turcu Aug 25, 2010
    to format it ..just look in the menu for a feature called storage ..access it ..and inside you will have 2 choices for internal memory and memory card ...choose memory card ...and than on the memory card open options and choose format ..this will erase all on the card and make it usable ..
    if you do not find the feature...just insert the card in a card reader ,,and format it in a computer ..by right click on it into the my computer folder and choose format ..(remember into the computer the mode is FAT32 for this kinda cards..)
Need a Memory card
This is an OLD camera that uses CF cards - the earliest type of card storage. I have provided a link to the manual for the camera - it is considered as Powershot S20 based on your PC1002 number. On page 21 of the manual (page 24 of the pdf) there is a table listing the compatible cards. Another Canon link (provided) states you can use CF Type 1 cards.
https://support.usa.canon.com/kb/index?page=content&id=FAQ100296
http://www.wedophones.com/Manuals/CamerasAndCamcorders/Canon%20USA%20Canon%20PowerShot%20S20%2032MP%20Digital%20Camera%20w%20Manual.pdf
Aug 29, 2016 | Canon PowerShot Cameras
I have a Canon powershot S20 w/ an E50 problem. The CF card isn't the root cause. Would like to reload the firmware to, hopefully, fix the problem. Where can I get the firmware from? Free of charge would...
Canon uses a copper sheet to cool the IC that menages the CF memory card. Use air to clean the copper sheet and make sure it cools the IC by firm contact, will fix your camera.
Dec 15, 2010 | Canon PowerShot S20 Digital Camera
Powershot s20 cf card error
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this link.
Sep 29, 2010 | Canon PowerShot S2 IS Digital Camera
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Canon A10 - "CF card error" with new 4GB card
You need to format new cards in the camera before using.
Apr 05, 2010 | Canon PowerShot A10 Digital Camera
Canon rebel xt error messages
error 99 can most times be remedied by taking a standard pencil eraser and carefully cleaning the gold contacts at the back of the lens and the gold maching contacts in the lens opening of the camera... BE CAREFUL not to let eraser crumbs into your camera... keep it clean... reset the battery and give it a whirl.... did it solve the 99 issue?
for the CF it refers to the cf card... here's what I've found on this:
Canon reports that this error code may appear on your digital camera’s LCD (liquid-crystal display) when there is an error reading from or writing to the inserted CF (CompactFlash) card. This error code occurs most often after a user has tried to eject a CF card before the camera has finished writing data to the card.Solution:
Canon suggests that you first try to use a different CF card. If you do not see the error message when you use the new CF card, the first card is probably damaged.
Before you take the next step, drag the files from the CF card to a location on your hard drive to back up the files. Next, you can use Windows’ ScanDisk utility to check the CF card for errors. If you use a Mac, you can use Disk Utility (in Applications\Utilities\) in OS X.
If ScanDisk or Disk Utility fails to resolve the CF card problem, insert the CF card in your camera again. Then format the CF card. On most Canon cameras, you can do this by pressing the Menu button, selecting the Format tab, highlighting Format, selecting Format, and choosing Yes. Make sure you have backed up the data on the card before you do this. Formatting the card will delete the images from the card. After you format the card in your camera, use ScanDisk or Disk Utility to check the CF card again. If you still encounter errors while using ScanDisk or Disk Utility, you should discard the CF card because it is damaged.
If the error still occurs after following the steps above, your camera may need repair. Contact Canon’s technical support for further assistance.
hope this solves your issues....
let me know
K
May 29, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
CF AND 99 error.
Hey mus326,
According to the manufacturer a cf error code means there is a problem with your cf card, and error code 99 is a general error code which is often caused by using a lens other than a Canon lens. When formatting the cf card make sure you are formatting the card in the camera, and not using a computer to format the card. If you still can't get the camera to work I would suggest you have it looked at by an authorized service center.
Sincerely,
Allan
Go Ahead. Use Us.
May 05, 2008 | Canon Rebel XT / EOS 350D Digital Camera
CF Card
Please post back the error message you notice.
Mar 22, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error 50
The "E50" error code indicates formatting a storage card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another storage card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other storage card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the storage card for errors. Use ScanDisk to check the storage card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the storage card on the computer before you check the storage card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the storage card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot S20 Digital Camera
Memory card error - E50
Error Code "E50" (CF card formatting error) When a camera error occurs, an error code like "Exx" will be displayed, where the x's represent numbers. The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. If the same error occurs when you are using the CF card supplied with the camera, please contact the retailer where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a CF card: - Do not remove a CF card or disconnect the camera's power source while the camera is recording, loading, or erasing data on a CF card. - CF cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a CF card. - Place the CF card in the supplied case for storage. - Moving a CF card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the CF card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condensation forms on the CF card, put it aside until the water droplets have evaporated completely. - Do not use or store CF cards in the locations subject to dust or sand, high humidity, or high temperatures.
Aug 11, 2005 | Canon PowerShot A85 Digital Camera
Canon PowerShot S20 Digital Camera Logo
24 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
