Question about Haier HLP21E Top Load Washer
I have recently moved into a new flat. When I tried to connect my washing machine hose to the tap/faucet I realised that the faucet was smaller. How can I connect my washing machine pipe if the faucet is smaller?
    Sniper:
  • 174 Answers
Tap will be 1/2 or 5/8 bsp you need to know which and get a 3/4bsp to 1/2 or 5/8 reducer. 3/4bsp is standard size now. Or change the taps to standard size. just realized you may not be uk in which case this may not apply . look in your manual for connection size.
Posted on Aug 24, 2010
ERROR CODE 1e
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate
You may try the following link, too http://www.lg.com/us/support/answers/front-control-top-load-washers2013/control-panel
Sep 19, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What is the error of 1E
Sep 19, 2015 | Washing Machines
My fuzzy logic LG washing machine, is no longer spinning or washing the clothes its showing error
Check another faucet in the house to make sure your household water pressure is adequate.
Reference:
May 19, 2015 | LG Washing Machines
I bought a Parkside pressure cleaner,but I have no idea how has to be connecting?Becouse I can't connect by top water.Probably has to be connecting where is washing machine?Help me.Thank you.
You need a garden hose and outdoor spigot although it is possible to connect where the washer connects but is a real pain. You can also get an adapter to connect a garden hose to your "Tap Water" faucet but it is not recommended as you will likely break the faucet off.
Mar 12, 2011 | Garden
I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Jun 29, 2009 | Whirlpool Washing Machines
Samsung washer
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 28, 2009 | Samsung WF337AA Front Load Washer
Leaking tap?
leaking on faucet end? probably bad o-ring in fauct head ..leaking on washer end? possible hose is cross threaded on inlet valve take hose off and try to reconnect watching closely as you tighten trying not to cross thread plastic connection can sometimes be recut
Aug 29, 2008 | Washing Machines
Hooking my washing machine to the kitchen faucet
See that your hose does not have any clogging in the filter screens; connect to the cold. careful with the threadings; turn on faucet & check for any leaks........start washing. Will tell you later how to get a manual. Regarding hot water, your machine can heat it if it has provision.
Dec 19, 2007 | Washing Machines
Haier HLP21E Top Load Washer Logo
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
