Question about RCA TruFlat 27F520T 27" TV
RCA Truflat tv picture quality is diminished, it is like the brightness is too low, but that is not the problem. We can turn the tv off and on and sometimes the clear picture will appear again
  • RCA Master
  • 5,568 Answers
CRT sets use a special transformer called 'flyback.' This device has two, sometimes three adjustments on the transformer, one of these is a focus adjustment. All of these controls are variable resistors and these can develop internal contact problems at the 'wiper.' This problem can often be solved with some success by turning the control back and forth several (many) times to clean the contact area inside.
This is an area of high voltage but the adjustments are insulated so stray fingers may get a surprise so be careful if you try the following- - Pull AC plug from wall. - Remove the back cover; 6-8 screws, may be hex head or Phillips - In good light, look for a round peg-like control on a larger black device with a top cable running toward the side of the picture tube, with 'Focus' molded next to it or around it. - MARK the current position (correction fluid works well) - If you can identify the right control, turn it back and forth several times; most of these can be turned with a flat blade or a Phillips screwdriver. - Return it to its original position.
If the power cord can be separated and plugged into the set, turn it on and observe the picture; it may be worse than before but don't panic, you did move it. Best case is to have a mirror so you can watch the screen while not poking your screwdriver in the wrong place. This (focus) is not a potentially damaging adjustment, the other one (or two) can be since they may act on the high voltage level, focus does not. Adjust for the sharpest picture.
There are other defects which could cause this problem but the above is the most common and the others require technical background and a couple of pieces of test equipment.
If this resolves the problem, you may get many more years from your set instead of going 'flat/big screen' and being really ********** when it fails in a year or two.
Posted on Aug 24, 2010
What remote control goes with the rca truflat tv?
Hello
Just buy one RCA RCR 311B universal remote control. You will get all instrucions and setup codes along with it. The setup codes for this remote with RCA TV are.
1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205
gopakumarg43_34.jpgThis is the picture of RCA RCR 311B.
Aug 30, 2011 | RCA TruFlat 27F520T 27" TV
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
I have a (RCA) TV and theres a parental control lock on it that wont let me do anything. Is there any way to reset my tv or get a code for it? heres the numbers: service no. 275650TYX3 MODEL: 27F50T SERIAL...
Try this...turn off the television, then press the "Volume Down" button on the TV and the "Clear" button on the remote at the same time. Press them both for five seconds, then release and turn on the TV. When it's time to enter your parental password, the system should ask you to reset it. If you need to reset other settings such as picture quality or brightness, look for an "All Reset" option under the "Setup" or "Others" menus. Selecting this option returns all the settings to their factory defaults.
Feb 11, 2018 | RCA TruFlat 27F520T 27" TV
My DVD player is hooked up to my RCA truflat but i cannot find the picture. I lost the original remote to my RCA truflat and am now using a RCA universal remote. How do I get picture on my tv?
There should be a button on the front of the TV that says TV/VIDEO or INPUT. Turn on the DVD player and put a DVD in it and press play. Press the TV/VIDEO button until the picture is present.
Good Luck....
Jan 19, 2010 | RCA 14F512T 14" TV
Tv has sound but not picture
i have the same problem, whatever happen to plain ole tv, that's why I'm on this site, looking for answers. I misplaced my manuel.
Nov 04, 2009 | RCA TruFlat 27F520T 27" TV
RCA TruFlat Won't Turn On!
Same problem with Sony. Unplug for 36 hours at wall and it should work
Aug 11, 2009 | RCA TruFlat 27F520T 27" TV
The tv screen is green
This is usualy a bad picture tube. are there any bright lines running across the screen? It would be helpful if you could give the brand and model number
Mar 12, 2009 | RCA TruFlat 27F520T 27" TV
52" RCA TV Plus color TV (12 years old)-picture is diminishing
Go into the menu and set contrast to full, bring brightness up to an appropriate level after.
Aug 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca truflat 27"
You can take off the back of the tv. Look for the red wire at the top of the tube. Follow it down to the part that it goes into. On that part (transformer) there are 2 controlls. The one marked SCREEN, is the one you can turn up and watch the screen at the same time. If the tv shuts off, put that control back to the original position. If it brings up the brightness, then it is fixed. If not, take to a repair shop.
Jun 13, 2008 | RCA TruFlat 27F520T 27" TV
RCA TruFlat 27F520T 27" TV Reset
Buy a new remote.
Look around the tv and find the menu button.
Generally there is a separate power button.
You can also download the manual:
http://tv.manualsonline.com/manuals/mfg/rca/27f520t.html
Dec 02, 2017 | RCA TruFlat 27F520T 27" TV
RCA TruFlat  27F520T 27" TV Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
