Question about Maytag MSD2732GR Side by Side Refrigerator
The Munions surrounding the doors is hot. I find that the cooling fan is not turning. the terminal where the wires come from the fan to plastic block look orange possible burnt
  • Michael Brennan Aug 24, 2010
    the fan spins freeley I noticed that wires coming fan to plastic terminal block appear orange
    possible from heat and are brittle
    wires look orange The fan spins freely. The two wires coming from fan to plastic terminal block on left side with other wires looks orange with one in block brittle. Do I need new wiring?
  • 1,998 Answers
Also known as your compressor fan has stopped working you can order the fan directly from marconeappliance parts and they will send the fan to you you will have to reinstall new wires but before u do order the fan fix the wires first or remove the fan and take a hot wire and connect it to the fan and see if the fan spins no sense in spending money if the thing works if it doesnt work then you willhave to install the new fan which will fix the heated side panel problem. please remember to rank how this opinion has helped in your appliance situation and if you have any other questions message me back have a great day
rickead1
Posted on Aug 25, 2010
  • 4,059 Answers
That fan not running is the problem. If you have voltage to the fan, replace the fan. It should turn freely when you spin it.
Posted on Aug 24, 2010
Who doesn't the engine cooling fan turn on
check the plug connector at the rad cooling fan motor for a bad or damaged connection. then you can run jumper wires from the battery to the terminals on the fan motor itself. if it does not run then the fan motor needs replacing. this is a common problem.
Sep 20, 2014 | Cars & Trucks
I have a 03 aztek and the cooling fan is not comeing on when hot changed relays, thermostat is good ,water pump is good changed the coolant temp. senson on thermostat houseing but still no fan . both fans...
Pull the plastic Module plug apart ,Figure out witch is the hot wire to the fan, End the ground wire ,Use a jumper wire to ground it to the body of the car Some where like a bolt going into the body or the engine some where, Take anouther jumper wire end hook it up to the hot wire on the fan .Touch it to the positive terminal on the battery to check if the fan comes on, If it doesn,t the fan motor is shot. They don,t last for ever,
Nov 03, 2012 | 2003 Pontiac Aztek
I have 7 wires, how do I wire it Red Green White Black Yellow Orange Blue
Conventional heating, air conditioning and heat pump thermostat wiring labels, wire color codes and the corresponding function description: Terminal
Designation
Wire
Color
Function
Description
Rh Red 24 Volt Hot for Heating Rc Red 24 Volt Hot for Cooling Y1 Yellow First Stage Cooling Y2 Blue Second Stage Cooling G Green
Grey * Energizes Indoor Fan W1 White Energizes First Stage Heat W2 Black Energizes Second Stage Heat O Orange Heat Pump
Reversing Valve
Energized In Cooling B Brown Heat Pump
Reversing Valve
Energized In Heating C Brown** 24 Volt Neutral
(Common) leg
Hope this helps
Tom Miller
Broadcast Eng
Sep 07, 2011 | Hunter Fan Company 5/1/1 Programmable...
How do i check the cooling fan my car is over heating
HOT WIRE COOLING FAN USING JUMPER WIRES TO BATTERY.IF FAN DONT RUN WHEN HOT WIRED FAN MOTOR BAD NEED REPLACING. IF FAN RUN WHEN HOT WIRED. CHECK COOLING FAN FUSE AND RELAY.IF ALL IS GOOD.YOUR ENGINE COOLANT TEMPERATURE SENSOR NOT WORKING.IT CONTROL COOLING FAN AT SET TEMPERATURE IF SENSOR OPEN OR FAULTY THE COOLING FAN WONT TURN ON.CHECK COOLING FAN WIRES FOR DAMAGE.IF ALL STILL CHECK OUT GOOD HAVE VECHICLE SCANNED FOR PCM FAULT.IF IT FAILS NO COOLING FAN WONT TURN ON.
Dec 13, 2010 | Hyundai Elantra Cars & Trucks
The munions surrounding the doors are hot. I find that the cooling fan is not turning. casing very hot
The munion heaters will get hot if the fan is not working to keep the box cold. The heater are there to keep the doors from freezing shut. The fan motor is bad from your description and will need replaced. I hope this helps. Please leave feed back. Thank you.
Aug 24, 2010 | Maytag MSD2732GR Side by Side Refrigerator
On a Paragon 8145-20 Defrost Timer, I know you land the refrigeration circuit on terminal 4, the heater on terminal 3, but what goes on terminal "X" and terminal "N"
Link below has 8145-20 wiring diagram:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Terminal N is 2nd wire needed to complete circuit.
In 240V 8145-20, there are two hot wires.
One Hot connects to terminal 1, with jumper to terminal 2.
Second Hot connects to terminal N, and this will power the clock motor and timer.
Terminal X is for temperature or pressure termination switch.
Defrost cycle works like this:
Timer is running but switched OFF.
Refrigeration fan is ON.
Timer switches ON, defrost cycle begins.
Refrigeration fan turns OFF.
Hot gas defrost turns ON.
When temperature-or-pressure limit switch reaches trip point, it switches timer OFF.
Refrigeration fan turns ON again.
Hot gas defrost turns OFF.
Aug 01, 2010 | Paragon 8145-20 Defrost Timer
Outside ac unit operates but no blower. Fan "on" does not operate from thermostat. However "heat" works fine furnace and blower. ???
Go to furnace and shut off power, remove blower door compartment. Inside you will find a control board where thermostat wires are connected. Should look something like this:
R-Red Wire= Power
G-Green Wire= Fan
W-White Wire=Heat
Y=Yellow or Blue Wire=Cooling.
It sounds like you have a bad motor speed. So try this:
With Power Still Off, on the same control board there is a terminal usually marked Cool and Heat. There should also be a couple of terminals that are named park. The wires hooked to these are the fan wires..
Exchange the Heat and Cool wires on the terminal board. Put everything back together and try cooling again, if the fan comes on
then you have a burnt out motor speed. Go back to furnace and change
the heat and cool wires around, next if Cooling had the black wire hooked to it, put yellow or blue on Cooling and black to park.
Note: The reason why you put the blower door back on is because it
has a door switch that if not properly seated, you wont be able to power
up anything
Jun 22, 2010 | Heating & Cooling
2003 trailblazer back air stays on after the truck is turned off
hi, there is a technical service bulletin published by general motors about these trailblazers and this problem, it is very common to have this problem if you own one of these. the rear a/c module is located on the passenger side in the very back underneath the plastics and bezels in the back. there is a blower resistor module that controls the fan speeds and recieves input from the control panel that gets too hot and melts the plastic surrounding the wiring connector and allows the terminal inside the connector to short the fan control wire to battery power. if this is the case, you will have to replace the resistor module, the wiring and connector, and sometimes the blower motor. you should contact you local gm/chevy dealer for parts though, they have the wiring pigtail so you replace just the connector end, and the new style resistor module, and if i remeber right, i think there is a air shield in the kit to install to improve air flow inside across the resistor to help cool it down. the blower motor when running produces the cooling ability for the resistor, if there was no airflow across the resistor, it would overheat almost immeadiatly. take the rear plastics off and the rear seat out, and have a look, you should be able to find this problem pretty quickly.
Jun 23, 2010 | 2003 Chevrolet TrailBlazer
My cooling fan won't kick in after i put a new radiator in i c one wire hanging on the right close to the radiator but was dark when i installed it not sure if that the problem
well do not no wire hanging may be if you can tell if its red blaike yellow you could of frogot to put wire on fan or sensor or you have air in system you need to make shere you do not have air in system
Aug 21, 2009 | 2006 Chevrolet Cobalt
The air conditioning wont turn on. The fan turns on but when it tries to cool it just goes back to the fan.
Compressor won’t Start
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Aug 01, 2009 | Danby DPAC8399 Air Conditioner
Maytag MSD2732GR Side by Side Refrigerator Logo
37 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
