Question about Garmin Nuvi 660 GPS Receiver
Nuvi 650 touch screen not working - Garmin Nuvi 660 GPS Receiver
  • Garmin Master
  • 2,130 Answers
Common problem. Please see this link for more info:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Sep 03, 2010
sharcnet
  • 2130 Answers
SOURCE: The touch screenon my Garmin Nuvi 600/650 won't
This is a common problem with units having the serial numbers beginning with "14V", "12P" and "143". It's caused by a defective SHARP touchscreen and needs to be replaced. Please see this link for more info:
- Jim
Posted on Jan 21, 2010
sharcnet
  • 2130 Answers
SOURCE: Garmin - Nuvi 650 - Touch screen dead/unresponsive
This can be repaired for far less than what you think. Please see this link:
- Jim
Posted on Sep 11, 2009
  • 23 Answers
SOURCE: Touch screen not working on garmin nuvi 670
Has this been solved? Hold power switch to right for about 30 seconds then follow on screen help to recalibrate screens
Posted on Jun 12, 2009
  • 1111 Answers
SOURCE: my garmin nuvi 650 will not go to next screen it
have you tried the master reset?
plug it in to the usb port on your computer for a few hours.if that fails,then try the master reset.
note: that the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update.
download the updater HERE
(actually i would do this either way)
bill
Posted on Sep 27, 2009
sharcnet
  • 2130 Answers
SOURCE: my garmin nuvi 650 is locked, the touch screen
Please explain "locked"..... do you mean locked with a PIN code or locked in that it wont accept any inputs from your finger?
If the second, I can help you with that issue. Please see this link:
- Jim
Posted on Dec 11, 2009
Hi I have a garmin nuvi 650. the touch screen not working? what should I do? Thx.
Common problem. Please see this link for more info. Too much info to copy and paste here:
- Jim
Sep 11, 2011 | Garmin nuvi 650 GPS Receiver
Try to remove the battery and insert it back into your gps device and turn it on. If the screen does not still work, then you need to reset the nuvi, by holding down the power button for about 15 seconds, then the unit will restart, that way the touch screen should respond. If it still does not work, then you need to calibrate the screen to get it to work. To calibrate the screen, follow the sreps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi,
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears (white screen with touch dot),
  5. Then follow the on screen instructions.
It might not work trying it once, so you have to try it over time till it works. Calibration is the last resort of all solutions, so if calibrating it does not do the work, then it means it a an internal problem.
Dec 25, 2010 | Garmin nuvi 650 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Nuvi 650 touch screen stopped working
My Garmin Nuvi 650 would boot up and load maps, but I could not enter my access code. Screen would not respond. Turned off & on a number of times, but still same problem. This occurred on first use after upgrading the maps. Thinking it may have overheated on the dashboard of my truck, I held the device in front of the air conditioner vent for about five minutes to cool it down. When I then turned it on, it worked fine. For the rest of my 3-week vacation, I kept it cool & out of the sun when it was not turned on. No problems after that.
Jul 17, 2010 | Garmin StreetPilot c340 GPS Receiver
Touch screen not functioning
Please see this link. Most likely uou have one of the newer SHARP touchscreens that is known to fail prematurely.
- Jim
Dec 15, 2009 | Garmin nuvi 650 GPS Receiver
Garmin Nuvi 650 Touch Screen trouble...
Yes, this is a common problem with a new style screen being used by SHARP. Please see this link:
- Jim
Dec 07, 2009 | Garmin GPS
Garmin Nuvi 660 GPS Receiver Logo
921 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
