It's not the camera, but the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
SOURCE: I need free drivers for my GE A735 Digital camera
Go to:
www.fixya.com/search/p926483-general_electric_a735_digital_camera/driver_free_download
SOURCE: ge digital camera A735
your batteries might not be putting out enough voltage. try using new duracells
SOURCE: GE a735 digital camera flash not working
Make sure your flash has not been turned off, check your settings. You may try changing your flash settings, most cameras have a setting for fill flash (flashes every time). If it still is not working make sure your batteries are fresh. If you have tried these two things, I would say its broken. If its still under warranty take it back, if not just use it and forget the flash. Flash is useless past 12 feet in most point and shoot cameras.
SOURCE: I cant get my laptop to recognize my GE A735
You can download the firmware and manual from
http://www.general-imaging.com/us/supportDetail.aspx?id=788
There is also a battery firmware upgrade notification you should be aware of at
http://www.general-imaging.com/uploadedFiles/40_Support/A735-A835-Service-Bullet.pdf
