Question about Texas Instruments TI 30XIIS Scientific Calculator
How do I fun summation on the TI30XIIS - Texas Instruments TI 30XIIS Scientific Calculator
HOW DO YOU ADD UP TH FINAL MARKS?
It depends on your jurisdiction. In Ontario, the term mark has a weighting of 70, while the summative and final exams have a combined weighting of 30.
To illustrate, let's do an example.
Term mark worth 70% of final grade - 70
Summative mark worth 10% of final grade - 80
Formal exam mark worth 20% of final grade - 90
Your overall final mark would be as follows
70 x 0.70 = 49
80 x 0.10 = 8
90 x 0.20 = 18
Overall Mark 75
Good luck,
Paul
Jun 21, 2016 | Office Equipment & Supplies
Find summation(x-xbar)^2, given that summation x =160 and n=10 whre there are no data points given?
You need one more piece of information, either the standard deviation, the variance, or the sum of squares. With only the two pieces you give, there are an infinite number of solutions.
Feb 28, 2014 | Computers & Internet
Scientific Notations
Press 2nd [SCI/ENG], use the arrow keys to select SCI, then press ENTER. To control the number of digits after the decimal point, press 2nd [FIX] and select the desired number.
Dec 08, 2013 | Texas Instruments TI30XIIS TI-30X IIS...
Notation summation
Since x^y doesn't depend on i, the sum is simply n*(x^y).
There are 1 to n terms, each of which is x^y.
Jun 07, 2013 | Casio FX570ES Scientific Calculator
How to use pi button on ti30xIIs
Press the pi key to put the value of pi into the machine. You can then use it as you would any other number.
There's nothing fancy or tricky about it. It's there only to spare you from remembering and typing in the value of pi.
Jul 24, 2012 | Texas Instruments TI-30 XIIS Calculator
What is a proses summation
There isn't any such thing.
If you mean "process summation" or "process of summation" then it can refer to any number of things in mathematics. If you mean something else, then I can't guess.
Jan 24, 2011 | Sigma (20) EX DG Lens Converter for...
How do i put the square root of a problem in a TI
Use the square root key accessed after pressing the [2nd] function key.
Press [2nd] [Square root key] 121 [ ) ] [ENTER]. Do not forget the right parenthesis, even if you did not have to enter the left parenthesis.
The result should be 11 (one of the square roots to remember).
Hope it helps.
Oct 24, 2009 | Texas Instruments TI-30XA Calculator
Texas Instruments TI 30XIIS Scientific Calculator Logo
648 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
