Question about Car Audio & Video
My 2005 Passat radio will not play. The LED readout states "check." The fuse is good. Sometimes, I remove and replace the fuse and the radio works momentarily, then stops at the readout states "check" again.
  • 2 more comments
  • grimkag Aug 25, 2010
    There is no "brand" referenced in either the drivers manual, or on the equipment itself. It seems to be a standard Volkswagen radio/cd/tape deck system. I have changed the fuse, even though the old one was fine. Occasionally, removal of the fuse, and re-installation will enable the system to play, but when you turn the car off and restart the engine, the radio/cd/tape deck system restarts with the word "check" on the LED readout screen. The manual mentions various messages and how to deal with them, but does not mention the word "check."
    BTW, this is not a car speaker/subwoffer problem. This is a car radio system problem. Was I directed to the wrong "expert?"
  • grimkag Aug 27, 2010
    Thank you for your response. Sorry I am so tardy, but we had a power failure in our building that lasted over 24 hours. Looking at the batter connections, they seem secure. There is a wire off the positive connection that is loose, but I can's seem to locate where it might have been attached previously. It has a three female connection, but I can't seem to find the male connector to make a connection. Where should I look. BTW, my radio is a VW/Monsoon unit.
    Thanks a million. This makes perfect sense since removing and replacing the fuse sometimes causes the radio to temporarily come back on. I'll work on the problem this weekend and let you know.
    President:
  • 1,851 Answers
It looks like loosy connection. Check the connections again, mone the 2 power cables and the ground cable in order to locate the one that is missing the connection. Keep in mind that from the 2 power cables, 1 must be connected at a permanent 12Volt power (from the battery) and the other one at the ignition switch so that the radio works when you turn the ignition switch. Temporary you can connect both the power cables at permanent 12Volt from the battery, but beware that in this case if you forget to power off the radio when you park your car, the radio will be at on state so your battery may exchaust.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution. Please consider leaving a 4-thumbs rating; I'd appreciate it greatly.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 25, 2010
  • 1,868 Answers
Hello! Please identify which option stereo system is equipped in your vehicle?.....Guru..............Saailer
Posted on Aug 24, 2010
  • David Burbee
    David Burbee Aug 27, 2010
    Hello! Under the drivers side carpet is the Comfort System Central Control Module (CCM)...There is a three wire connector...Wire colors...Brown/Red...Orange/Brown...And Orange/Violet...All three wires are a multiple to the radio connector...This is the only three wire connector that has wiring which feeds the radio..If these colors match...It identifies the plug...The loose wire needs to be soldered...Why the plug is not connected bothers me...An answer may be that is is just a point of multiple...Also, coming out of the plastic housing of the CCM is a ground wire that connects to a stud in the floor panel...Check for rust/corrosion...Clean and re-connect...However, the problem may very well be a poor connection on fuse # 37...This is a common fault on Passat's..."CHECK" is telling you it has lost power (sorry to remind you; Lol)...The fuse holder has a history of loose connections...There is also a fuse (Amp/Dsp 30A) which is an in-line fuse to the amplifier...Wire color is...Red/Brown; Also has history of bad connection....Keep me posted.......................Saailer
The Audio system on my 2005 Solara Convertible just died. I checked and replaced the 25 amp fuse (the old one still looked good), but still no power. What else should be checked?
dead as in all functions and modes dead, all.
well it can only be 2 things
1: no 12vdc to head, (use a 10 buck voltmeter from walfart>?)
2: head end is dead.
25amps is the wrong, fuse. even 10 amps is good for 140watts.
the fuse is stated in the operators guide lost that?
some cars its mark,, RADIO.
the fuse that looks bad is
the fuse that looks good,can be , in fact. bad. what most techs
do is use ,yes, the voltmeter again, to measure bothsides of fues
keyon, radio on, to check all fuses related to radio (audio)
12v on both sides wins
if 12v makes it to the Radio and amp (if external amp then that too must have power, for sure) then the radio is bad, or amp.
if the radio scans and finds stations(not stated) then the amp might
be bad or lost power.
radio 101, over and out.
Jan 01, 2015 | 2005 Toyota Camry Solara
My 2008 passat radio not switching on. When I turn the lights on, the radio lights goes on, but the radio will not switch on. I removed the radio, and replace the fuse at the back of the radio, aswell as...
Get your circuit tester out and check if you are getting a live feed with the ignition on and a live feed with the ignition off to the radio! Then check the earth wire is making a good contact! If this is ok then you will need to get the radio tested!
Dec 29, 2014 | Koolertron For VW GOLF IV Passat B5 old...
Radio won't light up
Does it play? If so, you have a burned-out light bulb in the radio. You'll have to remove the radio from the dash to replace the bulb. (That's assuming it doesn't use an LED.)
If the radio does not play at all, either it isn't getting power or the radio has failed. To check if it's a power issue, first check for a blown fuse and replace if necessary. If the fuse is OK, reach behind the radio to make sure the power cable is plugged in securely. If neither of these work, you're going to need a new radio. They're not worth repairing. And don't go to the dealer -- OEM radios are very expensive and not all that good. Go to a place that sells and installs name-brand radios. You'll get something twice as good for half the price.
Aug 30, 2014 | Cars & Trucks
2006 passat Radio stoped working
Check fuse at relay panel and back of radio. If both are ok, most likely needs stereo.
Dec 03, 2013 | 2005 Volkswagen Passat
Part of the lcd readout isn't working
sometimes resoldering helps other times the selector internally doesn't make a connection very well. if neither of those are the problem then its time to replace the led display.. its only a few $.. and a shop should do it for less than $18.. plus $1-$7 for the part.
Feb 03, 2011 | Cobra 29 LTD CB Radio
2005 impala radio works, no sound or warning charms for low fuel.
If you purchased this vehicle used sometimes people will take the fuse out to stop the chime for low fuel and doors open. If your saying that the radio works and there is sound, this has nothing at all to do with the chime for the low fuel. Check the fuses and see if one is blown or removed. I hope this helps, good luck..
Sep 23, 2009 | 2005 Chevrolet Impala
Check engine light comes on even though i replaced the faulty camshaft senors
take it back to shop because.some of the 2.8 v6 passat had 2 cam sensors.one for right bank and one for left bank.if shop already replace them.they need to remove code from computer.
Jun 01, 2009 | 2004 Volkswagen Passat
Radio LCD readout
the LCD is back-lighted by a tiny bulb inside the radio chassis, pull the radio out, remove the sheet metal top cover, you will see a small twist in/out bulb socket at the rear of the radio display screen, remove it, take the bulb to a good full service parts store like NAPA or the dealer, the bulb is about $2.
Jan 07, 2009 | 1997 Jeep Grand Cherokee
2005 Malibu MAXX car stereo dead, rear radio too.
Please check your owners manual for the location of the 10 amp fuse for the radio. On some models you have to reset the security feature on the radio/CD player for it to work.
The info below has been stated to work on a no go radio. I have not confirmed this procedure.
Remove the lower fuse box cover, with the power off, removed the 10 Amp fuse for the "Radio." the fuse may be good. Fuses are diagrammed in the owner's manual. With the fuse removed, start the car, turn the car off, replace the fuse and turn the key to "ACC" to see if the radio was "Reset."
Would the alarm cause the radio to malfunction? If your Anti Theft lock was activated check your owners manual under radio and check for a 4 number password. Sometimes it is taped to the upper part of the glove box. If you do not have the CODE you will need to take the vehicle to a dealership or a repair center. They use your vehicles vin number get the code.
Jul 21, 2017 | 2005 Chevrolet Malibu
Car Audio & Video Logo
66 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
