Question about Kenmore 25862 Top Load Washer
Cold water wont work - Kenmore 25862 Top Load Washer
    President:
  • 670 Answers
Are you saying that the machine is not letting cold water into the machine? If so, the problem has to deal with the cold water inlet valve. Disconnect the cold water supply line at the machine, check to see if there is the screens are blocked with debri.
If it is ok, it's probally the water inlet valve which is the problem. It is an easy part to purchase at any appliance supply house or online. Hope this helps you.
Posted on Aug 24, 2010
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
Cold water wont go into machine. I have replaced the intake vaulve and still wont work. Hot water will
Check the screen washer on the cold water hose. Many times these get plugged up and keep the water from flowing into the machine.. turn the valve off at the wall, and then take the hose loose from the valve.. check for cleanliness and flow. You can buy replacements at the local hardware stores..
Sep 13, 2010 | Kenmore Washing Machines
My cold water on my whirlpool estate wont turn on only hot water works. When i set the cold /cold water water wont turn on . On hot/cold it turns on but only hot water comes out.
first thing to do is of course check to make sure the cold water is turned on.  sorry i had to put that in there.  you can take off the cold hose at the washer and check to see if there is a blockage such as calcium deposits which can block the line. if all that is clear then you will probably need to have the inlet valve replaced.
Jul 30, 2010 | Washing Machines
My washer cold water wont work the supply is good and it puts out hot water whats wrong
If I understand your issue correctly, you're saying no cold water gets to the machine. If that's true, then do the following:
Turn off the hot and cold water to the machine
Disconnect the cold water hose to the machine - catch the water from the hose in a small container
Check for a plugged water inlet screen - this is pretty common
Clean the screen, reconnect the hoses, turn on the water, check for leaks and try again
If no luck, you may have a bad cold water inlet fill valve, but it's much more likely to be a plugged screen
Mar 13, 2010 | Crosley Washing Machines
Spin cycle wont work
First : The machine will not spin with water in it. So you will half to start by checking the drain pump.
The water valve is what you will first need to check the cold water.
Jan 07, 2010 | Washing Machines
Washer wont allow cold water
Mixing valve should lock out the hot water when on the cold water setting. Either your hoses are crossed, or the mixing valve is flipped. To see if one of these is true, try it on a hot water setting to see if cold water comes in, or try just swapping the water hoses.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag neptune
Change the water valve again ,you most likely got a bad one.The odds of there being no cold water after a new valve is almost impossible.You can test the valve to make sure its working before you go to buy another one.
Apr 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
NO COLD WATER
the problem sounds like an elecronic faullt try swapping the hoses over and also check that the resistance readings on the valves are the same.some times if they are diffrent it can damage the pcb.hope this helps
Mar 05, 2008 | Washing Machines
Washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Feb 07, 2007 | Amana ALW880WH Top Load Washer
Kenmore 25862 Top Load Washer Logo
29 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
