Question about Xerox 8830 Copier
XC830 COPIER LETTER P SHOWS UP IN WINDOW AND WONT PRINT
  • 52 Answers
IS NOT DETECTING PAPER
Posted on Aug 27, 2010
Letter outline printing detail
your copier not set paper size.Paper seize is miss mach so several times print same print
Jul 13, 2012 | Canon imageRUNNER C6800 Copier
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
I can't print a letter from my microsof office word program. the printer works but when i try to print t6his letter i doesn't Hp photosmart c5280 all in one printer scaner copier , ineed and up date...
Check if the correct paper size is selected according to the letter size that you are trying to print,select custom size and give the specifications of the paper manually.
Open Solution center software on your PC, click settings>Printer settings, in the feature tab you have an option named Paper type, select plain paper and then click ok and close window and Solution center and try to print.
Sep 27, 2009 | HP Photosmart C5280 InkJet Printer
On/Off button red...letter
"P" flashing usually means No Paper or Load Paper. Check the Sensor. Make sure paper Sensor is not stuck in the Up position.
Sep 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
H-4 model xc830 copier
Performing a Fault Reset 14 will reset your copier and will help to clear error codes. 1. Turn the power off. 2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button. 3. Locate the Auto Button the lower left corner of the Control Panel. 4. Turn the power back on. 5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear. 6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5. 7. Program the copier as if you were going to make 14 copies. 8. Press the green [Start] button to store the reset code. The copier will return to the ready position. 9. Run a test copy.
Jun 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
Apr 08, 2009 | Konica Minolta DiALTA Di200 Copier
Xerox XC830 Copier--Paper jams as it is leaving the copier
Inside the copier on the rear side where the gears are you'll find the gear on the fixing roller is broken. You can call Sharp instead of Xerox because there are usually cheaper. The supplies are not interchangeable, but the parts are.
Good luck
Apr 03, 2009 | Xerox DocuColor 12 Color Copier
Xerox xc830
it does sound like the toner cartridge is empty or bad.
Apr 18, 2008 | Xerox 8830 Copier
Canon PC 745 Copier
not 8 it is an error code
please write other words
Apr 14, 2008 | Office Equipment & Supplies
Xerox xc830
try cleaning the optics under the glass.
Jun 20, 2007 | Xerox 8830 Copier
64 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
