Question about Home
Is there a repair kit to repair damaged finish for porcelain sinks?
Can I repaint a steel enamel finished sink? Has been scratched by clumsy wife!!
Yes you can. they make several products for this at the harware stores. You said enamel but are you refering to porcelain? To do the repair you will need porcelain repair compound and some high-gloss, alkyd-base paint that matches the color of the porcelain. if it is simply enamel then just match the color or repaint the whole sink using enamled paint. what you have to watch and worry about is if the repaired section will be contantly wet, if water gets under the paint it will bubble and flake off and make a mess. So the answer is yes but it may not be worth the trouble.
www.diybathrepair.com
Sep 12, 2011 | Microwave Ovens
Cracked porcelan
Try www.find-a-fix.com or just use any good quality porcelain repair kit. This kit may have a exact color match for you. take care and good luck.
Mar 08, 2011 | Kohler Bath Sink Undermount saree ...
My sink has a crack. can this be filled & sanded
Yes. Porcelain sinks can be fixed. Your local home improvement store will have it. It comes as a kit. easy to use and takes about 24 hours to cure.
Dec 25, 2010 | Blanco Axia Silgranit Anthracite 6S Drop...
Recomended cleaning for kitchen porcelain sink
Scouring powders or cleansers contain abrasives commonly used to clean and remove stubborn stains that are slow to respond to chemical action alone.
However, use of an abrasive cleaner may scratch and damage smooth finishes such as porcelain, fiberglass or enamel making it even more difficult to clean the surface in the future.
New kitchen and bathroom fixtures do not require a scouring cleanser to clean them of soap films and body oils. Dissolving soil by soaking with the correct non-abrasive cleaner (especially a foaming type that sticks to the surface) then wiping and rinsing usually does the job.
When cleaning older, abused fixtures, choose the mildest abrasive cleaner available such as a Soft Scrub -type product or baking soda, and apply just enough that, with light pressure, the embedded soils are loosened and may be rinsed away.
Aug 21, 2010 | International Thermocast Corp Thermocast...
Can you file the opening to make it larger for a new faucet on a 14-year-old porcelain sink?
try a rotozip with a porcelain bit u can get both at lowes hardware use water to cool when zipping
Dec 14, 2009 | Lacava Design DROP IN PORCELAIN SINK -...
PORCELAIN SINK UNDER GRANITE
Hi just unscrew from under sink use construction grade clear silicon screw it back in do not use for 24 hours and it will be ok
Apr 06, 2009 | Oxo Porcelain Pedestal Bathroom Sink,...
Surface scratches in my black bathroom sinks
You might try a vehicle buffer on them. If that doesn't work you will probably have to use a porcelain touch up kit that can be bought at your local hardware store.
Mar 29, 2009 | Home
How to repair porcelain/cast iron sink scratches
You can repair the sink with an epoxy based porcelin kit
Epoxy will not show brush streaks it will levelitself out do not get any kits from HD or Lowes they do not harden
Go to Sherwin Williams and ask for an epoxy paint for porcelin
As for removing the under counter sink
I would try cutting through the caulk adhesive
between the bottom of the granite and cast iron
sink with a hack saw blade
I have used a diamond blade on a grinder and
cut through but it was not a granite counter top
Be extremely areful to suport the underside of the sink with 2x4 blocks to prevent stressing the granite as you cut through
Good luck
Dec 31, 2008 | Home
Home Logo
48 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
