Question about Epic View 550 Treadmill
I am trying to take the motor cover off to replace the motor belt. I have removed the screws in the back panel, but the cover still appears to be in a bind and I cannot find any other attatchments in the schematics. Is there a trick to getting the cover off?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
There are 2 more screws located on the bottom side of the cover. You will need to fold the treadmill down to the ground, console should fold down on top of the walking surface. This will expose 2 holes close to the front roller bottom. These screws are phillips head and need to be removed as well. This will free your cover allowing you to remove it.
Posted on Aug 25, 2010
  • JIm Shipley Aug 25, 2010
How to replace belt on samsung dv218ae
Hello & Welcome to FixYa
Please follow the step by step instructions for belt replacement given in this video:
Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Samsung DV218AEW Electric Dryer
Hi i am trying to fix my belt on a beko condenser dryer as the old one has snapped can you help me please.
remove all the screws from the back panel and remove the heater cover (shaped inner panel fastened to the back panel).remove the cir-clip from the drum shaft and you will be able to pull the back panel away far enough to drop the belt down between the drum and back panel.refit in reverse.take the cover plate off the back/bottom right corner and using a tube or screwdriver,stretch the belt over the motor pulley.refit cover plate.job done
belt diagrams:
http://www.applianceaid.com/images/belt-config.JPG
Jan 08, 2011 | Dryers
How do you take apart a Danby Designer dryer to replace the belt?
INSTRUCTIONS TO CHANGE DRYER BELT DCD5505W-1, REMOVE THE SCREWS ACROSS THE BOTTOM OF THE FRONT THAT GO FROM BOTTOM UP
REMOVE THE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK AND LIFT OFF. REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THAT HOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT REMOVE THE FRONT SCREW FROM THE CENTER BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP
REMOVE THE 2 SCREWS ON EACH SIDE AT THE TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED REMOVE THE 6 SCREWS AROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT REMOVE THE 2 SCREWS ON EACH SIDE OF THE INNER BULKHEAD PANEL AND REMOVE THE PANEL AT THIS POINT YOU CAN REPLACE THE BELT,
IDLER, AND MOTOR MOUNTS THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THE BLOWER COVER THEN UNTHREAD THE BLOWER WHEEL FROM THE MOTOR SHAFT.
May 11, 2010 | Danby DCD5505W Electric Dryer
Here are the Danby instructions: First Make Sure that Dryer is Unplugged from outlet.
THE FRONT THAT GO FROM BOTTOM UP. REMOVE THE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK AND LIFT OFF. REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THAT HOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT. REMOVE THE FRONT SCREW FROM THE CENTER
BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP. REMOVE THE 2 SCREWS ON EACH SIDE AT THE
TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED. REMOVE THE 6 SCREWS AROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT. REMOVE THE 2 SCREWS ON EACH SIDE OF THE
INNER BULKHEAD PANEL AND REMOVE THE PANEL. AT THIS POINT YOU CAN REPLACE THE BELT, IDLER, AND
MOTOR MOUNTS. THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THE BLOWER COVER THEN UNTHREAD THE BLOWER WHEEL FROM THE MOTOR SHAFT.
Mar 19, 2010 | Danby DCD5505W Electric Dryer
How do you take off the cover of my washing maching so I can put on a new belt?
Most washing machines and driers have the top held down by a strong spring clip.  Try to pry the top off gently but firmly with a large screwdriver.  Be careful not to chip the powder paint.  The back of the unit may have an access panel that is easier to remove screws from.
Nov 15, 2009 | Washing Machines
Replace belt on kenmore 97281100 dryer
You have to remove the front panel. The top folds back and there are 2 screws on the inside corners to release the front. Eric
Sep 07, 2009 | Kenmore Dryers
How do i change my tumble dryer belt on a beko thanks
Just changed the belt on a Beko DRCS68W and its a real pig! Remove the top panel and loosen all screws on complete back panel having removed circlip holding the drum spline on to the back panel. You will also need to disconnect wires/leads on top right inside panel to give you more space. Once you have done this you should be able to ease away the back panel far enough to get the new belt around the drum and over the drum spline in the middle. Then the tricky bit - getting the belt tensioned on to the motor drive spline. I did this before securing the drum and back panel, which gives a bit more flexibility. I also used about 15ins of 15mm copper pipe to ease the belt down over the motor spline. Hard part was getting the back panel back lined up with the screw holes as the belt tension distorts the casing. Finally hit on the idea of lying the machine on its side so the weight of the drum is pulling away from the motor and helping to line up the screw holes. Two and a half hours later job done! I guess if I ever did another it would be a whole lot easier but still not the type of job I relish!
Mar 06, 2009 | Dryers
Unsure how to access drier to put on new drive belt
Here is my own solution...
Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
Dec 15, 2008 | Zanussi TD4212W Electric Dryer
Whirlpool gas dryer model # lgr7646eq3
put back back on with top off remove screws in top corners of front panel remove bottom panel and screws holding blower/lint screen housing on remove door springs remove screws on bottom corners of front belt is probably lying in bottom
Sep 03, 2008 | Whirlpool LGR3624JQ Gas Dryer
How do you replace the drive belt on a Danby SCD 5505W dryer?
AT THIS POINT YOU CAN REPLACE THE BELT, IDLER, AND MOTOR MOUNTS
Jul 07, 2008 | Danby Dryers
Epic View 550 Treadmill Logo
109 people viewed this question
Top Epic Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
