Question about GE Interlogix Dvmre Pro 10 Channel Triplex Dvr with Cdrw
I have a10 channel DVMR -10eZT. When I tried to power it up all the lights come on for about a second then it shutf off with a flashing green light on the power button. Need your help.
My dvr is getting reeboot every 20-30 minutes when i conenct more than 10 cameras to the 16 channel DVR. Any solution
Posted on Apr 20, 2011
Check charged, in this trouble the current is 12V @ 7 amp but the chargen not is provides sufficient current. change the source for other in equal condicions and test.
Posted on Sep 25, 2010
What is a bonded channel signal
A 'bonded channel' is where the modem combines two or more channels together, for increased bandwidth.
The first light <Power> should be green, indicating power is on.
The second <Receive> light can be green or blue. When it is steady green, no bonding is occurring, (less bandwidth). A steady blue light indicates that the modem is using more than one channel for downloading. That is too say, it is bonding(higher bandwidth). That is the preference.... (If green or blue, and flashing, modem is still setting up....).
The third light <Send> can be green or blue. When it is steady green, no bonding is occurring, (less bandwidth). A steady blue light indicates that the modem is using more than one channel for uploading. That is too say, it is bonding, (higher bandwidth). That is the preference.... (If green or blue, and flashing, modem is still setting up....).
The fourth light <Online> is green, only....
If green and flashing, it is scanning for a connection.....
If green and not flashing, it is finished scanning....
The fifth light is the WiFI indicator of network traffic. (It also is used for WPS pairing, which I doubt you will use. Just stick with the WiFi indicator function...). It should be green, normally..., or non-WPS....
If #2 is blue, and 3# is green, normally...., I suspect that there is too much loss in your in-house system of wiring, and splitters. If that is the case, try putting a 8-12dB 'tap', in series with the whole house. That way, the loss is minimized for your modem to 'send' high bandwidth stuff upstream to the cable guys.... Be sure that the modem is connected to the 'tap' port, the house to the 'out' port, the cable company to the 'in' port of the tap block. I pasted a couple of examples of taps, at the bottom of this, to show the port labels. The tap loss to the rest of the house, is minimal to how well everything else works. I get a +15dB signal from the cable company. But, too many splits, left my modem in low speed upload mode. By-passing the splitters of the house, by adding the tap as only loss to modem uploading, my blue light always stays on. I also added an UPS, to cover power failures, and glitches. That was a well spent $50 special!
a3e73f03-c380-49da-8c63-30f45940ca66.jpg ef068fc8-f053-49ce-a577-d352db809e0b.jpg
Jul 30, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Toshiba satelite a15-s129 only blinking amber light flashes which will not go off ever. it keeps blinking and computer will not turn on or off.
If the blinking light is the power on LED (normally green), then you'll have to disconnect it from power and pull the battery to get it to stop. If you connect it back to power and the amber light blinks right away, or if you connect it to power, press the power button, and the power LED starts blinking amber, then you have a bad motherboard. I see about one every two years....
If you think this is a keeper (which I do), eBay is probably the best place to buy a whole or partial unit for a song and a dance ($30-$50 target price). The Satellite A10 and A15 series are hardware identical: A10's are corporate offerings with XP Pro, and A15's are nearly all retail offerings with XP Home, that being the only difference.
Sep 18, 2011 | Computers & Internet
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
Wd73737 blinking green power light
my tv keeps turning off i have a mitsubishi wd-73737 what can i do to fix it?
Jul 12, 2010 | Mitsubishi WD-73737 73 in. HD-Ready TV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Power light flashing green
the green power light is flashing green with the orange tick next to it and i cant get any wireless internet through it what do i do please help me
May 15, 2009 | NetGear DG834G Router
RED FLASHING LIGHT TV BLACK
does the television stay on ? these codes or flashing lights and designed to tell you about a problem that the internal computer had detected - a single flash then a double flash is a software upgrade notification -- call support at customer service and they will tell you exactly what the flash is related to then you can find the fix or repair with more information
Jan 25, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Power/Standby light blinks green then screen goes blank (off) for
I have a similar problem. Just found out a possible solution yesterday. I am waiting for my lamp but here's what you need to do if you have replaced your lamp. Go into self diagnostics mode: Switch of your TV via remote, you will see red standy by light. Now,on the remote press "Display"=>"Channel 5"=>"Volume Up"=>"Power Button". All these keys need to be pressed within 3 seconds. You will now enter the diagnostics mode. Press "Jump" on remote (bottom right) 3 times and then press "Channel 2" 9 times. The screen will display your current lamp hours used.
In order to reset your tv to factory settings and for the new bulb to work you must reset this timer or else your TV will assume you are still using the old bulb and will automatically kick in "over protection mode". So here's what you do once you do on the lamp hours display screen. Press the "Channel 3" button on the remote 3 times then "Mute" then "Press Enter" to reset the timer to zero. Your TV should now work as normal. And remember, whenever a part is replaced all factory settings must be reset to zero. To do this, follow "Display"=>"Channel 5"=>"Volume Up"=> "Power Up" to enter service mode. Finally, press "Channel 8" and then "Enter" to put the TV back to factory settings.
The above mentioned is usually performed by a service technician and they charge somewhere around $95 diagnostic fee. You just saved this charge. If you see flashing red lights count them when they flash in sequence. This is a code for the techs to tell them what is wrong. These flashing red lights sequentially flash from 0 to 10 times to identify a problem. Usually, when the bbulb goes bad the only thing that might need to be replaced would be a "lamp Driver" aka "Power Block Assembly" $116.25 online from Sony, or the ballast. Sometimes, if you do not have a video a Thermal FUse can go bad which only costs $4.80 for the KDF60-XS955 but the techs will charge you over $300. You can do this yourself if you can get your hands on a service manual.
Hope this info helps.
Good Luck to you all.
Jan 20, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Will not start
hi,it sounds like the main power port in the notebook is falty  try changing the angle on it or take out the battery and try it like that
hope this helps
Aug 24, 2008 | Toshiba Satellite A10 Notebook
GE Interlogix Dvmre Pro 10 Channel Triplex Dvr with Cdrw Logo
248 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
