Question about Lefroy Brooks POP-UP WASTE KIT AND ASSEMBLY - LB1383-ST - Satin Nickel
I have a lefroy tap CH1216. The pop up waste under the sink has a 4 way valve with the pop up valve pin running through the middle. It has a rubber washer & plastic pin inside that is broken causing a leak as soon as you press the lever on top to open the drain. I need to find out where to find a washer & plastic pin replacement to solve the leak?
2 Suggested Answers
whytfang
  • 170 Answers
SOURCE: bath waste
! goes over the threaded piece that screws into the piece that goes under the tub...and the other goes between the tub and the waste assembly thereby creating a sandwich with one on top and one underneath the tub....then screw the piece down tight through the tub and into the waste assembly and your good to go.....
Good luck and thanks for rating my effort.....the Fang.
Posted on Mar 31, 2009
Lefroy Brooks flush valve
Most flush valves are universal, but try to contact manufacturer and see if they can help, or try plumbing supply store (not a home depot)
Jun 21, 2013 | Lefroy Brooks Plumbing
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
My daughter pushed down on the plug & now it doesnt pop up!! lever at back doesnt work as the suction is so good!
drain assembly can be taken apart from under the lav. first loosen the stopper lever assembly. then proceed to loosening up the slip-nut on piping nearest to the drain. The drain is held to bottom of sink by a nut tightened to a thick rubber washer. Remove nut and remove drain. Dislodge stopper. Replace drain with fresh plumbers putty, underneath lip of drain where it makes contact with inside of lav. Reassemble drain piping and lever.
Mar 16, 2010 | NRS Cascade Brix single hole lavatory...
Very faint surface crack has appeared on base of my new enamel sink is it repairable??
If the crack is merely just a surface scratch and has NO depth to it. Then yes you can fix it and will never be able to tell a scratch was there before.
Most Home repairs store, i.e. Home Depot, Menards, Lowes carry scratch remover products. There might be a special kind specifically for enamel, make sure to check the package. The instructions are very straight forwards. Should not have any problems.
If it is a Crack, there is also like a bondo type product at the same stores that will fix it too...That takes a bit more technique to make sure its smooth and blends in with the rest but either way make sure you read labels and follow instructions.
I hope this Helps...Thanks for using FixYa.com
Aug 10, 2009 | Lefroy Brooks BELFAST SINK SLOTTED WASTE -...
States waste toner full, do i have to replace ? fs 1118mfp
I did not have a rubber plug, but removed the covers (sinked screws) and emptyd out the waste (aprox. 500 grams!).
apart from a fight with wife (I did it on the dinnertable) it did the job.
Jul 10, 2009 | Kyocera FS-1118MFP Laser Printer
Vessel sink's drain is leaking
a waste with a over flow does not work well with a vessel sink because the sink is to thin
Jun 16, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Bath waste
Mar 25, 2009 | Lefroy Brooks BATH WASTE KIT - LB1370-ST -...
Belfast sink repair company in ireland?
Sorry to disappoint you, but unlike steel or cast iron ceramic sinks cannot be re-enamelled. To do so someone would have to grind off the remaining enamel and then reapply and re-fire the sink: not only would this be very laboiur intensive but the sink would be unlikely to survive the mechanical and heat processes involved.
If you can't live with your crazed or cracked enamel then buy a replacement sink. They're still manufactured as there is a demand for them.
Mar 06, 2009 | Lefroy Brooks BELFAST SINK SLOTTED WASTE -...
Waste trap under bath leaks
put the putty under the flange where it makes contact with the inside of the bath, push the flange to the bath & tighten nut underneath. Trim off excess. Have an overflow pipe [not intergral] make sure the top & bottom of the collar have rubber seals
If the whole lot is plastic there may well be a leak down & along the thread of the waste.[it comes from the o/flow pipe collar] Silicone the thread and tighten nut. make sure it's dry first - silicone & water do not make a happy couple
Jan 26, 2009 | Lefroy Brooks Bath Waste Trap for Exposed...
Lefroy Brooks POP-UP WASTE KIT AND ASSEMBLY - LB1383-ST - Satin Nickel Logo
63 people viewed this question
Top Lefroy Brooks Plumbing Experts
Donni Steen
Tom Chichester
Are you a Lefroy Brooks Plumbing Expert? Answer questions, earn points and help others
