Question about EIO Estate Bagged Canister Vacuum
Were do I get replacement bags for the EIO varia estate vacuum?
were do I get replacement - 4dfa5d4.jpg advacak
  • Rank: Wiz
  • Rating: 83%, 100 Votes
contact the VDTA its a vacuum trade association. they will have contact info for all mfgs Call Suburban Vacuum Cleaner Parts at 1-877-592-5888 and they stock them.
Posted on Jan 07, 2011
2 Suggested Answers
advacak
  • 125 Answers
SOURCE: Eio Varia Estate Vacuum cleaner
Posted on Dec 02, 2008
Need replacement bags and filters for Hoover shop vac S6530-600. What are their specs?
The bag your looking for is PN 4010074X
These bags are no longer available but there are alternate replacements:
Look for any TYPE "X" Vacuum Cleaner Replacement Bags.
It appears the generic replacement is SV-230
http://www.kleansweep.com/hoover.htm
Here is another sournce:
http://www.amazon.com/Hoover-Vacuum-Bags-4010074X-Genuine/dp/B002ICAVYI
Use this link for a net search:
http://www.google.com/search?q=vacuum+bags+SV-230&rls=com.microsoft%3Aen-ph&oe=UTF-8&startIndex=&startPage=1&aq=f&aqi=&aql=&oq=
Thanks for choosing FixYa,
Kelly
Aug 19, 2011 | Hoover Wet/Dry S6530-600 Vacuum
Is it worth trying to fix my kirby vaccum?The motor smells like its burning when we run it
Generally the smell is the rubber belt that attaches from the motor to the brush.
Make sur the brush rollers are clean and spin freely, check the belt at the same time.
Please let me know if this helps.
Jan 09, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Where do I get teh EIO Baria Estate or cottage replacement bags>
www.eio-vacuum.best-price.com
This is the web site that you can order bags from...if this helped you please remember to click on the yes box on the way out if you are satisfied with your answer. THANK YOU AND GOOD LUCK
Oct 10, 2010 | EIO Estate Bagged Canister Vacuum
Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Sep 28, 2009 | Electrolux Vacuums
Oreck 4080 the bag fell off the vacuum,
If the bag doesnt have a bag holder then the bags just push onto the black connector - there is usually a hook at the top of the oval connector where the bag once pushed on, sits over the oval dust channel feeder and locks into place. Once the Oreck is switched on, the bag in theory should stick to the oval hole.
Jan 16, 2009 | Oreck Vacuums
Need bags with re-order #NVM-2B
If you are in the UK, the bags you quote are available from almost any Janitorial supplier. There will be at least one in most towns, usually on factory estates but with a trade counter. However some do sell from retail type shops.
Janitorial (or cleaning products) suppliers can be found in telephone directories, yellow pages, and most local papers.
Jan 12, 2009 | Numatic Henry Bagged Canister Vacuum
Aug 12, 2008 | EIO Estate Bagged Canister Vacuum
Vacuum does not power on
Check to make sure the front nozzle is on correctly and also the bag base, make sure it is pushed all of the way in. There are safety switchs at these 2 spots and have to be engaged to work. You can't tell by looking at the cord to know that it is ok or not. Use a continuity meter to check that one side on the cord isn't open. Could also be a bad switch, carbon motor brushes not making contact. Armature bad in the motor. So there are several probables for it not working.
Mar 05, 2008 | Kirby G4 Bagged Upright Vacuum
EIO Estate Bagged Canister Vacuum Logo
141 people viewed this question
Top EIO Vacuums Experts
Are you an EIO Vacuum Expert? Answer questions, earn points and help others
