Question about Motorola Mobility V360 Cellular Phone
Bluetooth is failing and my GPRS network not available
My bluetooth is not working it keeps on saying i must power cycle my phone and try again and i dont know what that means and my GPRS network is not available the is no E sign on top near the the network sign
  • 1 more comment
  • Anonymous May 07, 2008
    When trying to connect to bluetooth a "power cycle phone" error comes up. How do you fix this?
  • Raul cubila May 20, 2008
    my blue tooth doesn´t work. it is unable to find any dispositive
  • Anonymous Jul 28, 2008
You just switch off your phone for a while then switch it on again it must work.
Posted on May 12, 2008
How can I configure wlan and Bluetooth on Blu life play X cell phone?
Do you have a wireless (WiFi) home network ? Do you have any other Bluetooth-enabled devices that are turned on that your phone can detect ? You also need to tap on Scan for Bluetooth on your phone for it to start looking for available Bluetooth devices; maybe you need to do the same for WLAN.
Dec 31, 2014 | Blu Life Play L100a - Pink
Tell me how to connect internet from mobile i009 to bluetooth?
At first call to your customer care executive to send you for internet settings for your mobile. When you recive the settings then do the following things-
  • Install the settings first.-go to your message inbox and find the settings message when you open it then get the install option. Just click on install option.
  • Select your internet profile-just go to your internet menu and select settings. After that select Internet Profile and select GPRS option like Airtel Gprs/ Mobile Office if you are Airtel user.
After that Install Pc-Suite and
  1. Activate Bluetooth on your mobile phone (usually found under the Settings menu) and set it to be discoverable or visible.
  2. On the PC, find your Bluetooth program manager (in Windows XP and Windows 7, look under My Computer > My Bluetooth Connections; in Vista, look for Bluetooth devices in the Control Panel; on a Mac, go to System Settings > Bluetooth).
  3. In the Bluetooth program, select the option to add a new connection or device, which will make the computer search for available Bluetooth devices and find your phone.
  4. When your mobile phone appears, select it to connect/pair it to your laptop.
  5. If prompted for a PIN code, try 0000 or 1234 and enter it on both the mobile device when prompted and your laptop.
  6. When the phone has been added, you will be asked what service to use. Choose PAN (Personal Area Network). You should then have a working Internet connection.
May 18, 2011 | Computers & Internet
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Jabra bluetooth headset
  1. Start with your Bluetooth headset powered off
  2. Hold down the Answer/End key for 6 seconds. Light will turn solid blue.
  3. Release Answer/End key, Light will remain unchanged.
  4. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset.
Jun 14, 2008 | Cell Phones
TROUBLE WITH RAZR BLUETOOTH FOR IN CAR
was the phone charging?.
carefull with letting your phone plug in while you start or shut off your vehicle.
Paulo
May 30, 2008 | Motorola Mobility RAZR V3
Bluetooth won't power on
when you power on bluetooth and do nothing within 60 seconds it does not work and then you will have to apply "find me"
May 06, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Turn on bluetooth
When this happened to me I did a power cycle reset by removing and replacing the battery. When I turned on the bluetooth after this it turned on OK.
Feb 26, 2008 | Orange SPV M2000 Pocket PC
Bluetooth stopped working
have you tried turning off your phone and removing the batteries? Then try to see if the bluetooth works correctly again.
If all else fails, you might need your phone reflashed or reformatted...
Dec 09, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Bluetooth
aah same here.. i have the same problem with my motorola v500.. i've tried so many times to power it on and it just says "bluetooth power failed".. its really annoying..
please help!
Jul 08, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility V360 Cellular Phone Logo
79 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
