Question about Tunturi Sport & Outdoor - Others
J77P Treadmill, after 5-10minutes running error E1 comes up and machine stops. switch off at mains leave fro 30secs restart and Treadmill runs for another 5-10mins then stops again. Same start procedure required. Tightened belt because I suspected a slipping belt no improvement. Any suggestions
SOURCE: treadmill belt slipping
Hi, I have a Duratec usermanual, you can email me at crowsrluved at hotmail dot com and i'll email it to you, I think it should explain everything to you.
Posted on Dec 17, 2008
  • 33 Answers
SOURCE: I have an 'E1' error
It might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 33 Answers
SOURCE: When I start my Healthstream
Issue might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
SOURCE: I have a Freespirit Treadmill...Model
Don't laugh, but I'm working with an old Athlon Simplicity model to try and adapt the motor to a band saw. In any event. There is a magnet imbeded on the outside of the front belt roller. It triggers a circuit that counts the revolutions. There should be a small postage stamp sized black plastic piece near the belt roller that has two wires running to the circuit board. It may have come unplugged somehow. When I unplug mine - the motor stops and it displays E1.
Posted on Jan 21, 2011
SOURCE: I have an everlast folding
if your everlast speeds up all of a sudden it is your speed controller and this is useally caused by you not lubricating under the walking belt, a dry belt will cause friction which causes the motor to labor harder and then over time your motor will over heat and cause speed problems,
or buy pluging your power cord directly into your out let the surges with cause your controlle board to fail over time u must plug the power cord into a 15amp surge protector with min 500 jouls and 1 plug at all times,
you should always have a anti static mat under the whole treadmill if your treadmill is on carpet static can de magnatize your motor, and static will be pulled into the treadmill
so when u step on your treadmill u become charged with static so every time you touch your computer console you are causing little charges to your console which over time cause the computer to male fuction,
also watch out for useing cheap exstention cords they will cause major damage to your treadmills electronics and motor they can not carry the proper voltage from the outlet into your treadmill so this will daMAGE YOUR TREADMILL ALWAYS USE A HEAVEY OUT DOOR THICK EXSTENTION CORD make sure it is 15 amps and a heavy gage and no longer the 10-15ft
the longer the exstention cord the more power you loose
Tim Ramsay
Lubeatread Inc
lubeatread@sympatico.ca
16 feb 2011
this goes with all treadmills
Posted on Feb 16, 2011
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Treadmill triumph 400t has error E1
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
Apr 16, 2014 | Triumph Academy Sports 400T Treadmill
I keep getting an e1 error on the display.
Hi normally this error is coming from speed sensor in the main motor, and problem with the motor.
see the attached video. LED Blink Patterns on the Control Board Treadmill
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Dec 14, 2017 | Nautilus T516 Treadmill
Lifespan Pro3 - treadmill E1 error message
Hello
yes, your correct this could be the lower board with the issue.
The lower board could have blown a fuse, which you can check and replace quite easily. If the fuse is good look for other burnt spots on the board. The lower board may need repairing/replacing.
If the machine stopped while in use (after about 10min) then you will have a few other problems to check. Try adding silicone spray under the belt and if this has already been done then the running belt may need replacing.
E1 is never a good thing...
gymWorld.net.au
Jan 10, 2014 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
Jun 07, 2009 | Exercise & Fitness
Tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
Lites on control board read ( L 5 ) when machine is turned on.
the e1 symbol is an engineering error code for an electronics malfunction (actually is senses the motor not turning and giving an error. The most likely cause is the motor control board
www.twincityrepair.com
Mar 02, 2009 | Landice L7 LTd Pro Sports Trainer...
Sport & Outdoor - Others Logo
73 people viewed this question
Top Tunturi Sport & Outdoor - Others Experts
Bill Eager
Are you a Tunturi Sport and Outdoor - Other Expert? Answer questions, earn points and help others
