Question about Frigidaire FRT17G4B Top Freezer Refrigerator
5 year old top freezer, no ice maker. Fans run when turned on, not sure about compressor. Does not get colder than RT. Is it compressor or thermostat? Installed in cottage, left running, power outages would should it down and it would not come back on unless turned off/on.
  • 86 Answers
Unplug the refrigerator. Then take out the t-stat. There will be two wires on the back of the t-stat. Tape them together. Plug the frig back in. Now place your hand on the compressor to feel if its running. If it is you have a bad t-stat. If not look in the cover on the side of the compressor that has the wires going into it. You will be looking for burned wires or a burned relay coil. If everything there is okay look at the cylinder with the two wires. That's the capacitor. Does it look okay? If all of that seems fine then you may have a bad compressor. I hope this was helpful. Please leave feedback.
Thank you.
Posted on Aug 24, 2010
Why is my refrigerator not cooling properly?
Low on refrigerant gas due to a leak
Broken thermostat
Failing Compressor
Iced up evaporator
Feb 03, 2016 | Frigidaire Refrigerators
Can this ice maker be set to make more ice? And faster?
Icemakers cycle cubes from the air temperature inside the freezer so you can't do much to increase speed except adjust the freezer control colder. As to the bucket not filling, most icemakers have a feeler arm or plastic paddle that is suppose to sense the ice level in the bucket. Make sure the feeler arm or paddle at the bottom is free and no sticking or hitting anything. It needs to move freely ask the icemaker dumps the cubes. If your refrigerator is less that a year old it should be under warranty and a free repair to you.
Apr 30, 2015 | Samsung RF4267HARS Stainless Steel French...
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
We have a GE Side by Side Profile refrigerator and the freezer, at it's highest setting, can't keep ice cream frozen and the ice maker only puts out about 8-10 dumps in a 24 hour period. The model is...
Sounds like your coils are dirty which will cause inadequate cooling due to reduced heat exchange at the coils. Also check to make sure fan is running (next to compressor and should be running when compressor runs). The fact that your ice maker makes ice at all suggests that compressor runs, therefor no freon problems. Problem should be easily fixed with correct diagnosis. Hope this helps.
Dec 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker doesn't work
ck the ice creak and if too soft the freezer it too warm causing the ice mker not to work . freezer must be 15deg or colder . / also can be caused by slow fans or dirty coils . a very common problem in 650 's . cond coil up on top ( hard to clean .. mm
Aug 10, 2010 | Sub-Zero 650 / O Bottom Freezer...
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Amana BX21VW cool but not cold, compressor not working
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 13, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
COMPRESSOR RUNS, AND IS HOT TO TOUCH, FREEZER WONT STAY COLD IF O
either your evaporator and condenser coils are very dirty or your low on r22 freon
Jul 31, 2009 | Freezers
Compressor too hot to touch
Just make sure that all fans are running when the compressor is working. The compressor is a real fine built model to be 35 years old. The problem with machines and people, they just tend to wear out. If that refrigerator is something you want to keep and the compressor is worn out I would consider replacing the compressor. But the cost may not be something you would want to pay. I do this a lot and usual charge for parts, labor and warranty is $300.00
Hope you well on that Whirlpool!
Thanks, Sea Breeze
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
21 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
