Question about Whirlpool Refrigerators
Top of fridge is not cooking properly. Please help! Jane
  • Whirlpool Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Is this 10 cups raw or cooked rice?
Hi Jane:
Don't have any info about your question but,
if you start with 10 cups of raw (uncooked) rice you will end up wit a LOT of cooked rice.
I'd suggest that you re-read the instructions for the recipe or whatever it is you're up to.
Hope it's a raisin rice pudding.
MMMMMMMMM.
Dec 03, 2015 | Kitchen Appliances - Others
I'm looking for an intall manual for an LG Gas Cook top Model # LCG3691ST, and a LG Fridge # LMX21984ST and a LG wall oven #LWS3081ST. Can you please help?
Hello Lola,
I understand that you need the installation documents for a few LG appliances you have. I would be glad to assit you in this endeavor.
LG Gas Cook Top LCG3691ST -
Product (36")
Width 36"
Height 3 34"
Depth 21 11/16"
Cutout (36")
Width 33 15/16"
Depth 19 11/16"
Minimum Spacing (30", 36") 1" Back, 11 13/16" Left, 11 13/16" Right
Net Weight 44lbs (30"), 50lbs (36")
LG Fridge LMX21984ST - http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LMX21984ST&matchedModelCode=1000004146&searchEngineModelCode=LMX21984ST&targetPage=support-product-profile&initialTab=documents
LG Wall Oven LWS3081ST - http://www.lg.com/us/appliances/pdf/LWS3081STss.pdf
The above gives you the need deminsions to install the units.
Thank you for choosing FixYa.com
Justin
May 13, 2011 | Kitchen Ranges
Please tell me how this appliance works. Thank you. Mary Jane Howroyd Kitchen Aid Crock Pot
Make sure that what you are cooking is something that can be cooked in a slow cooker. Put all the ingrediants into the pot, plug it in and set it to either Low -This setting is the most used setting. Usually takes 8 hours or so depending on what you are cooking. High -This setting is faster and usually cooks in half the time as Low, but meats aren't as as tender cooked on this setting. Also make sure you put in enough liquid. You usually want the pot filled 2/3 with whatever liquid you are using to cook with.
Dec 27, 2010 | KitchenAid Crock Pots & Slow Cookers
Cant adjust fridge temperature
sounds like a bad thermostat
Feb 24, 2010 | Refrigerators
Can one cook with iron skillet on glass top electric stove
Cast iron is NOT recommended to be used on a glass cook top due to its weight and potential for damaging the surface. Cast iron also heats rapidly and retains heat for a long time. Its great for gas stoves, but not a good idea for a glass surface.
The best cookware to use should be lighter in weight, have even heating properties with a SMOOTH flat cooking surface on the bottom for proper heat transfer. Some cookware that IS approved for use on a glass cook top is baked enamel, stainless and copper.
NOTE: Cooper and Stainless can leave marks on the cook top, but these marks do come off with most approved cook top surface cleaners.
If in doubt, always refer to your owner's manual. It explains in detail how to select the proper cookware for your range and the limitations and/or characteristics of each. If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Frigidaire FEF366 Electric Kitchen Range
Kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Fridge not cold enough and build up of ice at back of fridge
May be your damper switch not closing your damper when it reaches tempature setting.
Dec 13, 2007 | Smeg FA311X Top Freezer Refrigerator
Range
On your oven, look in your manual and you can calibrate the oven +/- 35 degrees.If it is out of the range of calibration then replace your oven sensor or themostat which ever one you have.On your fridge I would recheck your drain hose from both ends and puor boiling hot water down drain.The only 2 reasons why you would have water on bottom of fridge is 1 a water leak or cloged drain.good luck
May 25, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Refrigerators Logo
22 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
