Question about Whirlpool Refrigerators
Water leaks into ice storage pan - Whirlpool Refrigerators
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Water leaks on floor, where isthe defrost drain pan? the manual indicates that water might build up in drain pan, the connections with the ice maker are all dry.
The drain pan is usually located closest to the floor - behind the kick space or toe space grill at the bottom of the fridge. Most often the water that collects in it is evaporated by the heat generated by the compressor and airflow from condenser fan located close to the pan.
Make sure the water is coming from the defrost drain hose - not from water sources elsewhere in the fridge (leaking water / melting ice into the fresh food compartment, etc.). If found, take action to correct.
Oct 19, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Drain pan filling up. I emptied the pan and about 24 hours later its full again. We have ice and water in the door the freezer is cold just pan filling
If your evaporator fan is working properly the water would evaporate back into your home or business. If the evaporator fan was not working the freezer would not freeze and fresh food would spoil. That is way too much normal condensate unless there is a leak around the door seal or leak in the cool water supply tank storage or filter area. Not knowing the model number I would think you may have a drain opening under the crisper drawer that leads to pan. And think it may be a good idea to turn water supply off until sure of the source. Click here=> Leaking Refrigerators Just What may Be Happening and Click Here=> Leaking Refrigerator's? Locate model number for Kenmore Here=> Kenmore Model Number Locator's Most other model number locators are about the same as on the left sidebar on the Leaking Refrigerators page. I will be here to answer further questions, and there are a lot of things to look for on that page, Thanks, Sea Breeze Click on Logo enter your model for parts breakdown=>
sea_breeze_114.jpg WHIRLPOOL PRODUCT MANUALS
I will be here to answer further questions, Thanks, Sea Breeze
Mar 13, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Fridge: 44103 side by side: I keep finding a
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Kenmore 44103 Side by Side Refrigerator
Leaks water in the refrigerator down the back under
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 15, 2009 | Hotpoint 18.2 cu. ft. Top Freezer No-Frost...
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Water leaking into crisper
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 24, 2009 | Kenmore Refrigerators
My fridge leakes water?
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 18, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water leaks into freezer bottom & floor
Aug 16, 2009 | Kenmore Refrigerators
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Refrigerator leaking water
There is normally a small shutoff valve installed in the water line servicing the ice maker; you might shut off the flow of water until you locate the problem.
Most drip pans can be slid out but it would be wise to lower the level with sponges or similar to avoid any more spillage than you already have.
If the 'knob' is centered it is probably the release knob for the grill, behind which is of course the drip pan.
Before damning the ice maker (although they are among the most unreliable devices known to man), I would pull the fridge out and examine the fitting where the water line is attached.
Any lime buildup or green corrosion around the fitting would imply that the leak is external to the cabinet and the leaked water is only accidentally making it to the drip pan.
If you haven't been getting blocks of ice in the cube storage bin, the shutoff valve is apparently working so you may get lucky locating the source of the leak.
Jul 07, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
14 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
