Question about Eureka Luxury Family 8-Person 2-Room Titan Tent
How do I take apart a Eureka model 96 ( aka The Boss Lite Cordless ) to replace its batteries ?
Agent Don
  • 310 Answers
SOURCE: Tear in Eureka Upright "The Boss" 4870
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=652524
Posted by kdunnett on Jun 07, 2008
I have a tear in the hose of an upright Eureka "The Boss" 4870 vacuum. I cannot find how to release the parts I need to get the hose out and put in a new hose (which I already have) I've searched the Eureka site and the owner's manual - nothing about how to replace the hose itself. Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. In answer to your question, the owner’s manual may or may not give an example to install the hose only, but on most vacuums the hose sometimes will screw in to the hose cuff on both ends unless if it is a hose assm then it will then twist and turn. Check with the
Eureka website and have them send out a schematic and owner’s manual for you so that you can install your hose properly. Sometimes you have to place hose glue on the end of each side in order for the hose to screw in properly. the website address will be listed below and they certainly should supply you with the owners’ manual and maybe a schematic of the parts breakdown that also may help. If not; check with your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 10, 2008
  • 46 Answers
SOURCE: Eureka the Boss SmartVac just turned off and won't turn on
Make sure it is not the electrical outlet that has tripped. If not then you basically have 3 choices. Cord, switch, motor. A service tech. should be able to diagnose.
Posted on Jul 25, 2009
Vac Belts
  • 701 Answers
SOURCE: My Eureka The boss Smartvac Model #4870 roller
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Posted on Dec 11, 2009
  • 13 Answers
SOURCE: Eureka Bagless Widetrack, The Boss, Vacume, model 5893
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis. It is Part #27871.
Posted on Jan 30, 2010
  • 52 Answers
SOURCE: bag model for Eureka Mega Boss 4460 type E
The model 4460 is for a Victory model which uses Eureka Type AA bags
They can be found at http://www.totalvac.com/eureka_aa_bags.html
Posted on Jun 12, 2010
Bag model for Eureka Mega Boss 4460 type E
Jun 10, 2010 | Eureka Mega Boss 4460DT Vacuum
A BELT FOR THE VACCUM CLEANER (EUREKA)
Here's a link to this exact belt for your vacuum cleaner on our website:
http://www.govacuum.com/1555.html
I hope this information helped you! Please be sure to rate this helpful if it did so other Fixya users with this vacuum can easily find this belt.
Thanks,
Chris J.
GoVacuum.com
Mar 30, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
How to remove the eureka the boss super lite filter
Push up on the black slide button just above the dump cup and hold. With your other hand remove the dump cup. Once you have the dump cup removed, pull up on the rubber section of the filter to remove and clean the filter.
Feb 13, 2010 | Eureka Boss Superbroom Bagless VacuumStick...
How do I change belt for Eureka Whirlwind Lite "Boss" model 450 A
Remove the 4 screws on the yellow top of the vacuum. The yellow plate will pop up exposing the belt and roller.
Jan 20, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
Battery Pack for the Eureka Boss Model 93B
tHE 96 F IS ALMOST THE EXACT SAME AS THE MODEL YOU HAVE. THEY HAVE THE SAME POWER TO THEM THE BATTERIES WERE JUST DIFFERENT
Jul 18, 2009 | Vacuums
Battery does not seem to fit machine
the light only shows that its plugged in, it wont shut off when its fully charged
Jul 03, 2009 | Vacuums
Belt location
If you torn the macine over, at the bottom of the sweeper you will see the belt on on side. You have to take the bottom part apart and remove the brushes to replace the belt. I hope this helps.
Jan 21, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Eureka will not charge
I just bought me one at a Goodwill in town for $4.00, like new!!
And sorry for this late answer, But it sounds like you need a new set of rechargeable batteries for it..
(IF your handy with a soldering iron)
Check it out online or look for a Batteries Plus store in your area..
http://www.batteriesplus.com/
May 22, 2007 | Eureka 77 Handheld Vacuum
Eureka Luxury Family 8-Person 2-Room Titan Tent Logo
70 people viewed this question
Top Eureka Sport & Outdoor - Others Experts
Are you an Eureka Sport and Outdoor - Other Expert? Answer questions, earn points and help others
