Question about Whirlpool GS6NBEXR Side by Side Refrigerator
When I open and close the side by side doors, immediately thereafter it becomes almost impossible to open either door. I would have to wait a long time before I can open either door again, like if they become glued.
  • 86 Answers
That is actually a good problem to have. It's the door gaskets sealing and there is a vacuum after closing the door. This can happen with good doors and gaskets. At the very least you know warm air is not getting in and keeping your frig running all the time.
I hope this helps. Please leave feedback. Thank you
Posted on Aug 24, 2010
GE Profile side by side refrigerator. The freezer side started to have leakage and caused frozen ice along the walls & Extreme suction on freezer side.
Not sure on this one, but many freezers draw a vacuum like that for a little while to try to get all of the air and moisture out. Commercial units are designed that way. If Ice is building up, there is most likely an air leak. Check the door gaskets and see if they are sealing up properly.
Aug 02, 2016 | GE Refrigerators
E1 F5Error on Whirlpool wall oven.
The main control and door latch are not talking to each other without testing impossible to say which one on the latch assembly there are micro switches which have contacts that are open or closed depending on latch position this tells the control the position when you power up the door locks the unlocks try a latch assembly first
Jan 13, 2015 | Whirlpool RBS245PRT 24-inch Single Wall...
Thin layer of ice on food in ge side by side
ice on food means door was left open for extended period of time and then closed. When door is left open humidity forms on food. when door is closed again the humidity freezes and becomes thin ice
Apr 21, 2014 | GE GSH25JFR Side by Side Refrigerator
Black stains on door
If it is inside, it is probably mold growing. Front loaders are much more susceptible to mold growth as they seal up tighter, and we all tend to keep the door closed when it is not in use.
Clean the inner door and bellows surfaces with a 50/50 bleach/water solution, applying liberally, and dump the rest into the tub of the washer. Add 1 more cup of bleach to the tub. Fill all of the dispenser cups with bleach. Run the hottest , longest cycle available with the hottest rinse cycle available. For us, it is the "sanitary" cycle. Run a normal cycle immediately thereafter to flush out residual bleach, and leave the door open. The cleaning along with the air drying will keep the mold from growing, and reduce the odors that these machines are famous for. Leave the door open between loads.
Best regards, --W/D--
Jan 23, 2011 | Zanussi FJS1225W Front Load Washer
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
Garage door closes and then opens immediately.
On the back of the motor unit you will find a control 'down force'. Turn this about 1/4 turn and try. This is for the reversing after moving a foot or so. Do not increase this control too much as it affects the safety.
If the door is hitting the floor and then reversing you will need to adjust the 'down limit' which is on the side of the motor unit. It takes a small screwdriver and you need to turn this control in the opposite direction of the arrow printed on the cover. Some tweaking will be necessary and remember if you run the motor too much a thermal switch will shut it off and you will have to wait 15 to 30 minutes for it to cool. This is normal so you will not be hurting anything.
Oct 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Denon CD player DCD 920. When using the open/close button once, the CD-door opens but when it is open, without any waiting time, it immediately closes again. If i operate manually the open/close switch on...
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Oct 14, 2009 | Denon Audio Players & Recorders
Power Door Light Stays on after battery was changed by a service department
follow this to reinitialize
1. Push the “MAIN” power switch to the “OFF” position.
The “MAIN” power switch is located on the instrument panel, left of the
steering column.
2. Confirm doors are closed, lights are OFF, and the key is out of the ignition.
3. Disconnect the negative (–) battery terminal and wait 60 seconds.
4. Reconnect the negative (–) battery terminal.
5. Push the “MAIN” power switch to the “ON” position and wait 3 seconds.
6. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
is completely opened.
7. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
is completely closed.
8. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
9. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
10. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
11. Push the “DOOR L” switch to close the left door and wait 3 seconds after the door is
completely closed.
12. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
13. Push the “DOOR L” switch to close the left door and wait for the door to
completely close.
With ignition in the “ON” position and both power sliding doors in the fully closed
position, the “PWR DOOR” indicator on the dash should NOT illuminate.
14. Confirm proper operation of both doors using the dash, B-pillar switches, and the
transmitter button
Aug 12, 2009 | 2001 Toyota Sienna
It is a side-by-side, and difficult to open the doors, esp. the refrig. side after having opened and closed the freezer door.
Hi, this problem are what we called, vacuum (air) lock, it's not a problem, it means that your door are sealing properly, you should wait 2-4 mins, before opening, doors will open normally, if you give it 2-4 mins, if you try to open door immediately after closing, you will get that sort of vacuum lock, what you could do when it's lock, push something flat between door gasket and ref. body, try not to break gasket, you will hear air releasing, wait few seconds and door will open easily. it.s quite normally for ref. door to air lock, especially when you try to re-enter ref. immediately after closing. it will go away after a while, good luck.
Aug 10, 2009 | Refrigerators
Doors extremely hard to open on both refrigerator and freezer
What you have is normal - it is intended to make a tight seal - something similar to pressurizing an airplane.
You should be able to get back in with no problem after about 30 seconds - time it on your watch
And wipe the vaseline off - it is both counter productive and may cause the plastic in your door seals to degrade.
Jun 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
29 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
