Question about Toshiba DKT3020SD Corded Phone
Setting up speed dial numbers
I am having difficulty setting up speed dial numbers. Instructions advise press 9876 to enter "User Programming Mode" but when I do that the LCD does not show USER PROG MODE but tries to dial the phone. There is no program button on this phone. HELP.
�� To enter User Programming Mode, press the Program button ...or dial #9876. "USER PROG MODE" appears on your LCD. The Program LED is steady green. �� To exit User Program Mode, press Program … or go off- and on-hook press #9876. Note A IPT equipped with a headset adapter ignores the hookswitch. It can only exit User Programming by timing out (approximately 15 seconds).
Posted on Jun 10, 2008
I HAVE THE ANSWER YEAH!!!!!
I just started working at my job and we call the same labs everyday and I really needed this speed dial to work.
These are the steps; I hope it works for you.
1.Do not lift the handset.
2.Press Redial
3.Put in the speed dial # example 60
4.Put the entire phone # inc. area code.
5.Press Redial
It should be stored.
Have a great day.
Posted on Jan 29, 2009
How do I reprogram a speed dial number on a DKT2010-H that has no display?
With a DKT 2xx0, you're probably on a DK-XX system
Try these steps
Leave phone on hook
Press REDIAL
Press SPEED DIAL
Enter Speed Dial Bin Number:
(Small system is 10-49 personal, 60-99 system-wide)
(Medium system is 10-49 personal, 600 - 699 system-wide)
(Large system is 100-139 personal, 200-999 system-wide)
Enter phone number
Press REDIAL to lock in number
If you're on a CiX system:
Press #9876
Press SPEED DIAL
Press Bin Number 100-199
Enter phone number
Press Speed Dial
Lift handset to lock in
Oct 06, 2014 | Toshiba DKT-2010 Corded Phone
How do I manually enter phone numbers into the "speed dial" directory of my Toshiba FD-9859 cordless telephone?
Welcome to Fixya
To program a speed dial on your phone, enter programming mode (press #9876 on your phone). The phone will display "USER PROGRAMMING MODE." Press the Spdial button, enter a speed dial number (100-119), 9 plus the phone number you wish to dialed (1-213-555-1212 for example), then press the Spdial button one more time to lock it in. To use a programmed speed dial, just press the Spdial button plus the number.
Thank you for using Fixya!
Apr 06, 2011 | Cell Phones
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
On a Toshiba DKT3020-SD, how do I enter the User Programming Mode. I tried pressing #9876 but it did nothing.
There are two programming modes. One is User the other is system. for user programming press 3,6,9,hold at same time. For system type hold *#*#1*2*3* and enter password 0000
Feb 04, 2010 | Toshiba DKT3020SD Corded Phone
INSTRUCTIONS NEEDED ON HOW TO SET UP SPEED DIAL NUMBERS FOR WHOLE OFFICE SYSTEM
Speed dial numbers 001 -255 (01- 70 on older versions) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
enter in the speed dial number you wish to program(40-70) .
Press the chg key
Jan 08, 2010 | NorStar T7316E Corded Phone
How do I change the speed dial outgoing number??
For personal speed dial numbers press feature *4 , enter in speed dial bank number 71-94 (256-279, it changes with different versions), enter number, press ok
- speed dial numbers 01- 70 are system wide speed dial numbers and are changed in system programming2.gif.System programming is done on M7310,M7324 and T7316 set only.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The 4 top line/feature keys are now used for programming2.gif.
Press the chg key
Oct 14, 2009 | NorStar M7310 Corded Phone
Where is the Program button on the DKT3220-SD ?
press intercom #9876 HOLD, flexible buttoon pressed to assign, press the bitton code, press again the bitton to set DND = 180 short key for extn 610+extn number to change display name must set at administrator phone usually is receptionist phhone
Mar 17, 2009 | Toshiba DKT3020SD Corded Phone
Speed dial access
It's easier if you have access to the database to put in names with the numbers, but in the simplest sense, you can take a piece of paper, write down locations, and start entering numbers.
PROG
They are added in sytsem speed dial from the first extension or one designated as the manager's phone. PROG **1234 gets you into programming and 001 is the system speed dial area. With a combination of NEXT's and ENTER, you can be looking at SD 000 (ie PROG **1234 NEXT NEXT ENTER NEXT) and you're ready to enter a speed dial in bin 000. The complete number starts with an access code (9) plus the number as you would dial it. For example 918005551212 ENTER puts that number in bin 000. NEXT will step to 001.
USE
Press INTERCOM or select a line and press AUTODIAL and dial the 3 digit code. If your installer was lazy, you will have a problem as "9" selects the highest line in a trunk group, one that you might not have. In that case, he'll either have to program the system properly, or you will always have to pre-select a line to use speed dial.
Notice that this is just hte instructions for SYSTEM speed dial. I guessed that it was what you're looking for. Personal speed dial is a different set of instructions and it could be either under a button or in your 10 or 100 number personal directory (so that's where the 2 digit SD's went :-))
Anyway, if you need those instructions and can't find them in the user manual, please post back.
Carl
Nov 21, 2008 | Panasonic KX-T7630 Corded Phone
Address book disappeared
I could not find the exact manual for your phone, but this one looks close and has instructions for programming the memory: http://www.conairphone.com/IBs/caller_id/cid200.pdf It says: BASIC MEMORY PROGRAMMING The CID200 comes with 10-memory dialing. NOTE: Your local phone company restricts the time you can have the handset off the base (off-hook). YOU SHOULD PROGRAM THE CID200 MEMORY WITH THE LINE CORD UNPLUGGED FROM THE WALL, IF YOU ARE GOING TO PROGRAM MORE THAN ONE PHONE NUMBER. Press [STORE] to enter memory store. Press the keypad to enter the number that you want to program. Press [STORE]. The ?MEM? will be displayed on the right corner of LCD. Press the memory location (0 to 9) on the keypad. The LCD will then return to the ?Answer-Ready? mode, and display the total call counter, new call counter, current time and date. Copy from the Caller ID to Telephone Memory Press [Up Arrow] or [Down Arrow] until the Caller ID memory location to be copied appears on the LCD. Press [STORE] twice to enter memory store. The ?MEM? will be displayed on the right corner. Press the memory location (0 to 9) on the keypad. The LCD will then return to the ?Answer-Ready? mode, and display the total call counter, new call counter, current time and date. If no key is pressed within 20 seconds, the LCD will return to ?Answer-Ready? mode. Repeat the above steps to store a different number in the same speed dial location, or to store a new number in a different speed dial location. NOTES: ? Pressing [PAUSE] will place a 4-second PAUSE into the number. Which may be required for accessing special phone services. ? You can store a number with up to 16 digits maximum. Only the last 14 digits will be displayed.
Mar 15, 2007 | Conairphone CID 244
Toshiba DKT3020SD Corded Phone Logo
570 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
