Bought a maxell USB2.0 flash drive 1GB, it will not store any data, keeps giving error message "can not be fomatted by windows, read only" please assist
    Problem Solver:
  • 9 Answers
Isolation..if it shows the same behavior on another computer, return the product for a replacement
Posted on May 05, 2008
Many errors after installing a new HDD on samsung R480 laptop
HI , there ,
Did you back up your data ? if so just recconect your old hard drive if you didnt format it and run windows go to my computer right click and click properties scroll down the the bottom and you should be able to see your product key jot that down and reconnect your new hard drive install windows and enter the product key.
as for the windows updates look up the error messages , you might have to copy the folder and delete the old oneas sometimes the donwload folderr gets corrupt.
Hope this helps .
Dec 29, 2012 | Samsung R480 Notebook
My 4GB pen drive store only 1GB data.when I sent more than 1GB data it shows system error.how can I solve it?
most likely the device ( pen drive ) is unable to use 4 gb of memory and thats why you have errors.
it could also be that you need to format the card correctly before use
Jul 31, 2010 | Kingston 4GB Secure Digital High Capacity...
I have just purchased an hdr-cx105e camcorder.It works fine on the hard drive but i have problems when adding a memory stick. I have tried a 16gb pro-duo just purchased, an 8gb from my sons psp, a 4gb and...
I read the manual in .pdf format off of the sony.uk site.
It does appear that it's not that hard to do what you did according to the manual, and you tried to use several memory sticks pro duo from Sony.
So, I do not understand why it would give you this error, unless the camcorder is faulty, somehow.
I would take it back to the place you bought it, and ask for an exchange for the same item after explaining what happened to you.
Good luck on this.
Jul 23, 2010 | Sony CX110 High Definition Flash Camcorder...
Bought a maxell 8gb usb flash drive. When I try to use it it comes up with message "insert disk into drive j". Any suggestions?
By trying to use it I take that to mean you go to My Computer and select the drive you believe it to be.
Try going to My Computer with the flash drive unplugged and then plug it in while watching My Computer for a new drive letter to appear. That will be the one to use.
If you select the wrong one you will get the message you are experiencing.
May 19, 2010 | Electronics - Others
My usb 4gb flash don my computer only reads in a secure K with 1m
See http://www.maxell.eu/FAQ2/FAQ.html
Venture USB contain two partitions - one named 'Public' and the other 'Secure'. Unfortunately we have noticed a compatibility problem between these drives and some computers running Windows Vista. In these cases only one drive is showing in 'My Computer' - usually the 'Secure' drive. As a result you are unable to access the user manuals and software which are in the 'Public' drive and cannot alter the partition sizes to allow access to the entire capacity.
Please follow the below instructions to resolve the problem:
1. Connect the USB to the computer
2. Please unzip and run the attached program
3. After completion please unplug the USB
4. Re-insert the USB to the USB port
5. You should now be able to access both drives.
Please click here to download the program and instructions
Dec 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My memory stick has stopped working, nothing shows up when I insert it into the computer...I need some of the files which are stored on it, do you know how I can fix it?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Nov 12, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Bought a 2gig maxell flash pen and wanted to use it for storing my work on it but i cant seem to work it and i need to save my work on this flash pen can some one please help
If you are using Win98 the problem is the USB ports themselves. You must locate and install USB drivers to make them functional. Other than that the USB should reconise the flash pen after a few minutes.
Now if it see it, to store in the drive, Save the information to a file/folder and then right click and choose SEND TO and pick the letter drive that is your flash pen and that will do it. If you can do drag and drop open the window that has your info and open a window that shows your pen drive left click and hold it down a drag it to the pen drive - when you see the + just release the left click and it should be on the pen drive.
Hope this helps you, good luck, please leave a rating, thank you kindly
Apr 26, 2009 | Computers & Internet
Flash error,need to back up data, and fomat player
1. Double-click My Computer on the Windows Desktop or in the Start Menu.
2. Locate the Removable Disk (X:) or Player (X:) icon that is associated
with the player. (X: equals the drive letter assigned to the ILO player.)
3. Right-click the Removable Disk (X:) or Player (X:) icon.
4. Click Format….
Reformatting your ILO player will result in the deletion of all tracks and
settings on the ILO player.
5. If you are sure you want to reformat your player, click Start.
Apr 17, 2009 | iLO (2 GB) MP3 Player
My U3 Smart SanDisk Cruzer Micro 2.0GB USB Drive Not Recognized
We can fix it -- and recover the data (provided it is recoverable -- which it generally is). If we don't get your data back, we ship the drive back to you and you pay nothing. We've been recovering data for over 16 years and are successful about 85% of the time.
Craftsman Computer Services, Cudahy, Wisconsin
Aug 02, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Pen drive problem
my pendrive in virus I cant remove even after the fomating the pen drive please give me the solution
May 05, 2008 | Transcend (589307) Media
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
