Question about Casa Vieja Probe White Ceiling Fan
Remote Control My Casa Vieja White ceiling fan runs by remote control only. It ran great for a while, but last year, the fan would change speeds, turn off and on on its own, and finally quit working all together. I installed new batteries - no luck - then bought a new remote control from Lamps Plus. That didn't work either, since each remote has to be programed, and this one wasn't. Lamps Plus said they'd get back to me if they could think of a solution. That's been over a year now. Any suggestions?
I had the same issue. I had to replace the remote control reciever located on the fan and that did the trick.
Posted on Jun 16, 2009
Why does the light go on by itself
Change e frequency settings in your remote and you should be OK.
Jul 12, 2014 | Casa Vieja Probe White Ceiling Fan
I purchased a Turn of the Century 52 inch remote ceiling fan, model 355-6786/6787/6788. After installing it I couldn't get the high speed button on the remote to activate the high speed on the fan. All...
I purchased a 'Turn of the Century-Apollo' model 355-6786 cieling fan. The only problem is no fan blade mounting bolts and nuts, instead I have 2 packs of mounting screws. I've dialed the Customer Service Department to no avail. Is there an unpublished WEB site?
Jun 26, 2010 | Casa Vieja Turn of the Century Antique...
I have a two wire (black white) ceiling wiring and the surveyor fan has four - black white blue and green. How can I connect so that the wall unit can control speeds and light turns off and on without...
When you only have two wires in the ceiling , that means that you have only one switch for this fan. The green connects to all green and bare wires and to the mounting bracket .. the white to white .. and the ceiling black connects to the fan black and blue wires .. In this installation the fan and light can be controlled independently with the pull chains
In order to have indipendent control at the wall you would need two switches and another wire going from the switch to the fan/light
Please Vote !
May 13, 2010 | Casa Vieja Casa Surveyor Ceiling Fan
I have a two wire (black white) ceiling wiring and the surveyor fan has four - black white, blue and green. How can I connect so that the wall unit can control speeds and light turns off and on without...
If you hook the black ceiling wire to the black and blue ones on the fan and the white to the white and green to the box it mounts to it will turn on and off with the wall switch and you'll have to use the switches on the fan to turn the light/fan on and off separately. Alternately, you could purchase a remote unit and install it according to the directions. Also, make sure you if you are replacing a light fixture with a fan that the box is strong enough to support it. Good luck.
Mar 22, 2010 | Casa Vieja Casa Surveyor Ceiling Fan
Casa Vieja ceiling fan
sounds like the pull cord switch i dont thunk you will be able to find a replacement proberly cheaper to buy a new celing fan
Jul 24, 2008 | Casa Vieja Probe White Ceiling Fan
Casa Vieja Intrepid Remote Control Sensing Problem
you need the same sensors in the remote as the one ur using now the old sensors will not work
Jul 05, 2008 | Casa Vieja Probe White Ceiling Fan
Casa vieja probe ceiling fan
one of the wires had disconnected and this seemed to cause the problem.
Feb 15, 2008 | Casa Vieja Turn of the Century Antique...
Casa Vieja Probe White Ceiling Fan Logo
550 people viewed this question
Top Casa Vieja Dryers Experts
tsalagi152
Stan Ford
Tom Chichester
Are you a Casa Vieja Dryer Expert? Answer questions, earn points and help others
