Question about Coffee Makers & Espresso Machines
I need the software or firmware that is loaded on the eprom of the thermoplan black & white cts-2. Does anybody know where I can get it? Is there a download
  • altair909838 Aug 24, 2010
    I have 2 machines. One works. I swapped the eprom chip from the one that works to the one that doesn't and voila. it fired right up. I bought a new chip in case that it is a dead chip. I have an eprom programmer. All I need is the software. I know that they have firmware updates. I just don't know where to find it.
    Thanks
  • altair909838 Aug 25, 2010
    I have gone to their training site. They discuss software updates in their forums but the places to download them are unclear to me. Maybe where they tell you to get them isn't there anymore. Anyway, they also sell an eprom repair kit. I am assuming it is just a cable since there is a com port in the coffee maker. So there must be software out there.
    Top Expert:
  • Coffee Maker... Master
  • 79,865 Answers
We have no software avail on Fixya for any device, contact the manufacturer, if they can't provide it no one can.
Posted on Aug 25, 2010
  • 11,800 Answers
That eprom isn't customer accessible so you can't upgrade the firmware. If your unit is malfunctioning it's because the processor has failed. Since i never heard of mainboard part replacement for any Thermoplan product, your unit is dead, unless you can find a second-hand replacement somewhere.
Posted on Aug 24, 2010
  • Azrael SRL Aug 24, 2010
    As i said the chip isn't a shop serviceable part and i never knew you can remove the eprom chip from the motherboard . You should try to contact them directly, maybe they will give you another eprom chip
    http://www.thermoplan.ch/english_new/kon...
Roger black 3.5kg flywheel rower. When I turn it on bleeps continuously with E1 on the monitor
Hi sir
this is typically problem with the EPROM
the firmware is corrupt
You can get the EPROM form the Company call them
and explain if they can send you the EPROm firmware.
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 23, 2018 | Exercise & Fitness
I have a intermatic ET1125C I have 30 amp fused load coming in,how EXACTLY do I wire it in and TWO independent outs for load 1 load 2 ? The diagrams are confusing I need to know color wire to #1-6 on the...
10-22-12
Intermatic ET1125 240Volt, two independent circuit Wiring absolutely shows on following link: Wire colors can vary. 240Volt line can be black-white, or red-white, or black-black. Non-code wiring can be white-white.
http://waterheatertimer.org/How-to-wire-Intermatic-ET-series-timer.html#1125
I have no idea what color wires you have. Or if circuit tests for 240V.
Include a photograph of your wiring, and list showing voltage on each wire, and color of each wire, and description where each wire comes from.
You should have two Hot wires L1 L2 coming from 30 amp breaker.
And 2 wires going to each Load (light, fan, motor).
Wire size should be at least 10 gauge.
Turn power ON, stand on dry boards, tape tester leads to wood sticks, and test each wire to bare ground.
240Volt circuit will have two hot wires.
Oct 22, 2012 | Hardware & Accessories
My nokia n95, screen just lights up & makes noise. u can call & recieve calls but nothing on screen except white back ground???I down loaded new face book has been updated & loaded google....
Hi you will need to replace the flex cable running from your main board to the screen, if this does not work then it is a Software issue and will need to be flashed with latest firmware, good luck
Aug 22, 2011 | Nokia N95 Smartphone
I need to know how a thermoplan cts2 works
The thermoplan is a disc-shaped airship of hybrid type, currently under development in Russia. The key feature of thermoplan is its two section structure. The main section of the airship is filled with helium, while the other section is filled with air that can be heated or cooled by the engines. This design greatly improves the maneuverability, alongside with the disc shape which helps resist the powerful winds up to 20 metre per second.
The project was started in the late 1980s and the early 1990s, with the first working prototype tested in 1991. That was rather small airship, and the giant thermoplan wasn't built at that time due to the problems caused by the economy crisis of 1990s. In the late 2000s the project was revived under the name Locomoskayner (?????????????) by the Russian company Lokomosky in Ulyanovsk.[1]
Dec 05, 2010 | Microwave Ovens
I have a thermoplan espresso machine and low water level in steam boiler message is coming up?
Problems with level on the CTS-2 Thermoplan espresso machine? Clean your probes. Make sure your steam boiler has a pressure of zero before you do this. It's best to have the boiler cold before you start. Remove both probes and clean them. Usually sand paper works. Use 1/4 copper tubing and bend it. Scratch the inside of the tank multiple times to remove the scale from the inside of the tank on that spot. This helps with grounding and the level system. This level error could also be related to a lack of water flow to the steam module or a scale problem at the inlet of the boiler. Sometimes the level board is bad or the water pump.. Also, the fuse may have blown in the the power drawer. Pray it's that! Contact lattefarms@yahoo.com for help or parts as we have overstocked. Good luck!
Sep 23, 2010 | Espressione Luna Espresso Machine
I deleted my bios how do i install my bios
The software in the BIOS is stored on an EPROM (Eraseable Programmable Read Only Memory). So, buy some hardware, namely an EPROM writer, remove the EPROM chip from the motherboard, insert the EPROM chip into the EPROM writer, download the latest BIOS-software from IBM's web-site, and load the software onto the EPROM writer, and rewrite the software onto the chip. Remove the chip from the EPROM writer, and reinsert it into the IBM motherboard.
Jul 17, 2010 | IBM NetVista PC Desktop
Error code u-2 solution
U2 00 EPROM error 11 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication error
U2 04 EPROM error 11 Main counter error 12 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication errorYou need the service help. It is no a distans work Good luck)
Mar 14, 2010 | Sharp AR-5320 Black and White Copier
Need Cadillac CTS 2006 remote programming info
I went to keylessride.com and looked up your vehicle and the remotes need to be programmed by a locksmith or dealer and being a locksmith myself I know that my prices are generally lower than dealers
Apr 01, 2009 | 2006 Cadillac CTS
Firmware upgrade
What version do you have now?
Here is the newest version posted on SharpNet:
Version H2.40 contains the following modifications: 1. H5-01 error detection changed from 3 successive errors to 5. (POD1) 2. “H3” errors eliminated when ICU detects E7-00 error.(PCU processing change) 3. Image rotate information retained during paper-out condition by specifying use of manual feed tray. 4. If L3-00 or L1-00 errors occur after upgrade, TC 26-59 settings must be changed. Refer to technical bulletin AR-337-001 R for instructions. AR507.EXE Contains all the files needed to upgrade the AR287/AR337 copiers using a PC, SCSI adapter, and 7 series Black & White Imager. (AR287 ~ AR507) Refer to Technical Bulletin AR-505-001. AR507.EXE contains the following files – ICU_H2_40.mot, ICU_H2_40.fd, PCU_H2_40.mot, PCU_H2_40.fd, OPE_H2_40.mot, OPE_H2_40.fd, and Flash5.1.exe
The firmware upgrade on these "toner bombs" is no walk in the park but I can walk you through it and provide the bin files and software. contact me at double-u double-udouble-u dot brianbell dot net for more information.
Dec 26, 2007 | Sharp AR-5316 Advanced Digital Imager...
Coffee Makers & Espresso Machines Logo
193 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
