Question about KitchenAid K45SS Classic Stand Mixer
Oil leaked when inadvertently stored on its side. what kind of oil do i need and where do i get it? thanks brian
  • 185 Answers
Gear grease is kitchen aid specific; sold by the can though a KA part supplier. while you're at it, replace the gear housing gasket as well.
Posted on Aug 25, 2010
Testimonial: "Thank you for the reply, very helpful. Thanks, Brian"
How do I replace the oil that came out when the mixer was stored on its side?
Mary Ann,
There actually is not actual oil inside the mixer. There is however GREASE. When the grease gets old it can begin to separate and then leak out like oil. The grease needs to be replaced in the mixer. You can find online video's on how to that and where to get replacement grease.
Oct 22, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Leaking oil from drive/mixer head
There could be one of two things wrong (or both). You might need a new seal or you might just need the machine to be regressed. Also, never keep your mixer stored on its side as this will automatically allow the machine to leak grease.
Nov 02, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
My mixer is leaking oil. How do I fix it?
Your mixer is leaking grease not oil. It is a simple fix. First you have to open the machine and regrease it. Once you have done that try replacing the gasket. Also, this particular mixer cannot be left on its side (some people store it sideways in a cabinet or under the sink) doing so will cause the machine to leak as well.
Oct 13, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Oil leak
instead of putting a gasket on tell him to take out all of the old grease out that is what has broken down and turning into oil causing a leak and if he can repace the seal around the agitator shaft replace the old grease with a high temp bearing grease or a good quality lithium grease
May 25, 2010 | Hobart A200 Stand Mixer
My kitchenaid mixer was stored on its side and leaked oil. I don't dare use it now. Can I replace the oil myself? There are no mixer repair centers anywhere near me.
your oil leaking is cause by a bad gasket or the gasket isn't seated properly. you can purchase this gasket but replacing it does require knowledge of the unit. part number for the gasket is 4162324. the grease can be purchased locally at any car parts dealer. generally a thicker paste type grease is used inside these units, but the original part number for the grease is 4160588 and comes in a container with enough grease for 5-8 mixers.hope this helps
Thanks
Oct 06, 2009 | KitchenAid K5SS Heavy Duty Commercial...
My stand mixer was stored on its side and leaked oil.
Called the Kitchenaid toll free number and found a local authorized repair center. Not a fixya solution, but at least a solution.
Oct 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid Mixer leaking oil
Hi Tim. Don't try to pour anything into the side openings, these openings are for the electrical brushes. You didn't state what model you have so my help is limited. Goto www.kitchenaid.com and click on the customer care tab. Enter your mixer's model# into the search window. Look for a parts catalog for your mixer. If there is one, download it.
Your mixer uses grease to lubricate it. If it's leaking oil, the oil and old grease must be removed and replaced. Chevron FM ALC EP-2 is a "Food Grade" grease, use it to replace the old stuff. The transmission housing and Planetary assembly will have to be removed to accomplish this. It's a messy, but necessary task. Once completed, run the mixer for a few minutes each week to keep the oil suspended in the grease, this will extend the life of the new lube. Good luck!
If this solution has assisted you please rate it. ricardok45.
Mar 28, 2009 | KitchenAid Food Mixers
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
Mar 17, 2009 | Hobart D300 Stand Mixer
Oil leaked from Kenmore mixer- model mumber 201
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Nov 18, 2008 | Kenmore KSM100 Stand Mixer
Mixer leaked come oil
Aug 04, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
127 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
