Question about Canon ZR85 Mini DV Digital Camcorder
Tape ejects immdediately when I load tape.
When I load a tape it makes a ding tone and ejects immediately. It will not allow me to loan a cassette. I tried different tapes and fully charged batteries, checked for the tab on the cassette to be in the rigght position.
It was working fine recently, Prior to vacation we saw some lines on the screen so I used a head cleaner to correct problem. It worked great for a few days then it decided not to accept tapes anymore. can you help?
  • 1 more comment
  • oliegodinez May 05, 2008
    Canon Z85R Will not accept tape cassette
  • monicahow Aug 24, 2008
    My camcorder will not allow me to load a tape. The take ejects immediately with the screen telling me to remove the tape. I've tried many different tapes, including tapes that previously worked fine. Any tape that I try to load is immediately ejected.
  • niyifat2001 Oct 19, 2008
    Just the same problem. I tried to clean the head becs its not playing nor recording too. Although, I have never clean it since I bought it. After the cleaning, it never accept any cassette at all whether new or old. What can be done to solve this please....
  • 3 Answers
I own a Sharp VL-Z1 DV video camera. I had this same problem and thought it was from using the ME Maxell tapes. I took the battery out of the unit and let it reset. Worked fine after that.
Posted on Apr 11, 2009
Broken tape. Cassette will not eject. How can I correct?
With power off, you will have to disassemble the player to get access to the tape mechanism. You will find tape is preventing the cassette door from closing to allow ejection. Remove damaged tape. Apply power and press EJECT. Turn power off and inspect the mechanism to be sure all tape debris has been removed, then reassemble the player.
Apr 12, 2016 | Sanyo DVW-6100 DVD Player/VCR
Model PV-D4732. How can I get cassette to eject?
When you press EJECT, the tape has to be withdrawn into the cassette and the shutter closed before the cradle can be lifted to clear the spindles and allow the cassette to be shoved out. You will have to disconnect power and remove the cover to expose the complex inner workings and I suspect you will find a tangle of tape or a broken tape. Some careful work with appropriate tools will allow the tape to be stuffed back into the cassette or (worst case) cut out. You can apply power again and you may be able to observe the sequence of ejection operations before reinstalling the cover.
Dec 23, 2015 | Panasonic Televison & Video
Why does the tape get caught in my toshiba rd-xv45kb recorder when i try to eject the cassette and the tape snaps
Not sure about the Toshiba but generally when inserting a cassette it is lowered onto the tape drive. There is a device that will register the presence of a tape which used to commonly be a phototransistor or similar mounted on a short post that is covered by the cassette.
Once the machine knows a tape has been inserted, when play is pressed two vertical rods move towards the heads dragging the tape with them enough for it to make contact with the sound head and wrap part of the way around the video head to make playback possible.
When stop, forward or reverse winding or eject is pressed those two rods move back to the starting position and the surplus tape is wound back into the cassette.
If a cassette ejects leaving a loop of tape that can mostly be pulled out little damaged the reeling in mechanism isn't working. If the tape is jammed and comes free only after breaking the rods aren't returning to the start position.
Engineers use an empty cassette case suitably modified so once the vcr cover has been removed the operation can be observed. The problem might be a worn belt or rubber drive wheel or a problem with the hidden linkages - or it might be an electronic problem.
Apr 22, 2017 | Toshiba Televison & Video
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Tape loaded normally but now won't eject. The unit just powers off after a few seconds.
Unplug the power from the combo unit and give it 30 seconds, now plug back in, sometimes this will eject the tape, if not! take the top off the machine and check to see if the tape is spewed in the mechanical section and around the video head, if yes! get a pair of scissors and cut the tape carefully to avoid damaging the video head and remove all tape deb-ri, now power up and eject the main cassette. But! if you find the cassette has loaded in place and the tape is still in the vhs cassette, this would indicate a loading problem with the main carriage, broken belt, bad idler assembly and possibly sensor issues.
Feb 06, 2011 | Sony SLV-D350P DVD Player/VCR
Handy cam video 8 XR keeps ejecting cassette any ideas please
thats is because the servo mechanism chip do not detect the cassette,
when its in the housing could be a sensor or the cassette in switch or mechanism its self (missalignement.)
hope that will help you
regards alan.
Oct 18, 2010 | Sony Handycam CCD-TRV37 Camcorder
The DSR11 will allow a tape to be loaded then it turns off. The tape loads and ejects OK but keeps powering off Any ideas?
since the tape loads, that rules out the cassette housing; the problem may be a defective reel motor, defective gear, defective tape sensor, etc.
Aug 03, 2009 | Sony DSR-11 DV / Mini DV VCR
I cant put a tape in!
when mechanism pops out to eject, wait until it completly comes out, deattache battery immediately, and Pull lever as per below mentioned picture. Cassette door will be open and place cassette. Close it and attache the battery. Camera is ready to Record or Playback.
Feb 25, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
Will Not Load Cassette
I have the zr850 which I have used less than a dozen times, and it does the same thing as you describe. Was told by canon tech people to try a maxell brand tape and a head cleaner tape. Have not tried their sugestion yet. camera is 3 months old.
Aug 07, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Canon ZR85 Mini DV Digital Camcorder Logo
391 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
