Question about LG WD-3243RHD Front Load Washer / Dryer
LG gas dryer to convert in propane
Please help me to make the conversion the natural LG
gas dryer to propane. I already changed the
orifice(dia=1.613 mm for propane gas) It has been
without success so far. The Instruction say Full open
for Natural gas, close to propane; and ask to change
the screw, what screw is that?
Please help me!!!
Thanks a lot for the attention.
Marcio
Serial # 709KWDJO1162
Model# DLG2526W
LG dryer
  • 1 more comment
  • Anonymous May 28, 2008
    where do I get the orifice?
  • bruce-stcruz Feb 24, 2009
    8 months later and the price is $40.00. However, I need to figure out how to open the blasted cabinet. Once my hands are on the manifold, the instructions with the tiny piece of brass are clear enough.
  • grgaz772 Apr 18, 2009
    Can someone help with info on removing the top cover of an LG front loader dryer after the L bracket is removed ?
    Champion:
  • 210 Answers
To get the orfice you have to contact LG. The part number is (propane gas) 4948EL4002b it runs around $20
Sgt 48
Posted on Jun 11, 2008
  • 489 Answers
If you replaced the orifice on the gas valve, then you must screw down on the adjustment screw on top of the valve.  Use a flat screwdriver and screw down the pressure adjustment screw till it stops in the down position.  Then the valve is set for propane use.
Posted on May 26, 2008
    Problem Solver:
  • 19 Answers
Get a licensed person to do gas conversions unless you do not value your life
Posted on Aug 03, 2008
On the white plastic pressure ajusting screw you should see a nut glued into a certain position turn the screw down untill you can not EASILY go any further. That should be the position you need. By the way for all those disassebling one of these front load dryers you have to start by removing the 6 screws on the L bracket from the top, remove the top metal take the two screw off of the plastic control panel, unplug all electrical, remove panel. you wil then see four screws on top of the front door panel, remove them, tilt from section forward lift and remove. under that is a drum support panel, four more screws there, remove them, then disconect internal light and door switch connectors, then you can lift ant pull out fron drum support panel. The drum belt tensioner can then be unloaded then you can remove the drum throught the front. You will then have the gas valve exposed to be able to change. Hope this helps someone. I took the time to type this because I could not find the information anywhere in the net!
Posted on Oct 30, 2008
  • cies59 Nov 30, 2010
    When adjusting this plastic pressure screw, I turned the nut glued so it allowed me to turn the white plastic screw in farther. Will this be a problem that I screwed it in farther.
    Champion:
  • 254 Answers
Actually you need to adjusted the gas valve setting or the screw you are talking about to the correct manifold pressure while the burners are on. This info you must get from LG it should have came with the oriface conversion kit this is essential as to insure the proper pressure while ignition is in process.
Posted on Jun 12, 2008
How do you revert a Kenmore Elite He5 gas dryer from propane to natural gas. Is it just changing out the orifice?
a little more than the orifice needs to be changed the pressure regulator and on some the whole gas valve body
Sep 24, 2016 | Kenmore Dryers
Lg5988 not getting hot after propane conversion
Could you tell me why you changed it from natural gas to propane?
Jan 24, 2013 | LG DLG5988 Gas Dryer
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Do I need a part to convert my Maytag gas dryer/washer combo back from propane to Natural Gas?
Yes you can, but whether you should is another matter. I purchased a new dryer and needed it to be propane ready...you need to get the proper orifice (which lets the gas in to the burners) changed out. Natural gas orifice has a larger hole than a propane orifice. In addition, the regulator must be modified. It may involve flipping an insert under the cap (typical of stoves) or it may require conversion parts packed in the conversion kit (order one specific to your drier). This regulator is part of the piping within the back of the drier.
Incidentally, conversion orifice(s) should be included with the drier and screwed to the body in a clip. When you change it over and label the equipment as converted to propane, put the old natural gas orifice in the clip and screw it back onto the body. Put the instructions in a paper envelope and tape to the outside of the body of the drier.
Apr 27, 2010 | LG WD-3243RHD Front Load Washer / Dryer
New BBQ chaged from propane to NG
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
Mar 11, 2010 | Uniflame Corporation LP Gas Outdoor...
Propane to nat. gas dryer
Good day,
Yes. Two reasons. The orifice that the gas comes out is a different size, and the regulator that determines gas pressure is disabled when using Propane, since propane has the regulator on the tank.
See here.
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
If you are not 100% sure what your doing, call a qualified company to perform the conversion. Isn't worth the gamble.
Propane is, unlike natural gas, heavier than air. It can pool in a low spot then ............
Dec 25, 2009 | Whirlpool GGW9200L Gas Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
Lg dryer - gas
If you do not have the original orifice you will have to order a natural gas orifice and replace the LP one with it. It is just a small brass threaded part with the correct size hole in it, located right at the end of the burner. For a LG dryer it is probably part number 4948EL4001B but you should get your model number from the sticker just inside the door and order the correct part from your nearest servicing dealer. You can find LG servicer's in the US on line at http://us.lgservice.com/index_b2c.jsp
Nov 02, 2008 | Dryers
Changing a gas ge dryer to a propane----convertion package we25x10014 directions show a picture of the control panel with 4 plug ins at the bottom and changing out the last one on the right for the new...
Converting your Natural Gas Dryer to Lp is taking it from a lower BTU gas "Natural" to a higher BTU "LP" value. The orfice on a LP gas valve is smaller because you dont need as much gas to make the same amount of heat. make sure you change the orifice. The little plug goes in the regulator of the gas valve, changing the valve from a low gas pressure Natural to a Higher Pressure LP.
If the kit doesnt look right, did you get the correct one?
Maybe you should call you LP provider they can do the conversion for you.
Jul 10, 2008 | Dryers
LG WD-3243RHD Front Load Washer / Dryer Logo
4,792 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
