Question about Nintendo Wii Console
Shuts down My wii will work fine fro awhile and it will shut down, we switched to a new power supply but that was not it. Is this a heat problem?
  • marf08 May 05, 2008
    My wii is simialar. When I fifa 08 (pal) on my chipped japanese wii (which I've used the ***. versioj freeloader on), it randomly shuts down - can't read disk or something. Some one help please.
    Matthew
I had this problem with my first wii. It progressivly got worse until it stopped working completly. Give nintendo a call 1-800-255-3700 (if its not chipped since that voids the warranty). They replaced my console under warranty.
Posted on May 05, 2008
The wii shut down by itself when i connect the usb back of the will HELP PLZ!!!!!!!!!
I had the same issue, but with an external HDD. Whenever I booted the Wii with the EHDD in the USB, it would turn on then off. I unplugged the EHDD, worked like it was supposed to. After the Wii went to the main menu, I plugged the EHDD into the USB, and it shut off. Sometimes it would take 20 seconds to shut off, but it did.
By accident, I found the solution. I had a bad power supply. I used a different power supply, and the USB issues went away.
Aug 14, 2012 | Nintendo Wii Console
The tv shuts off by itself. I will turn it on..and after awhile, it just turns off by itself, and then after about a minute I can turn it on again and watch tv for awhile, and then it will do it again.
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The faulty component(s) are heating up, tripping the fault control, and shutting down, it cools down again,and will restart, then the process repeats, it will eventually fail fully.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Mar 04, 2010 | Televison & Video
Appears magnetron fan not working.it over heats and shuts down after running for awhile. after cooling panel says rest and it appears to work ok but fan dosn't sound like it is running
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Mar 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Why is my 42" dlp tv turns itself off after awhile?
the power supply is not working fine. your tv needs preventive service so that semiconductor, diodes and capacitors are changed on the power supply before it switches off completely on its own.
do it fast
okay
Jan 05, 2010 | Samsung DLP HL-P5663W 56" TV
My 42HDS69 Hitachi has a recurring problem of not turning on. I unplug from outlet for awhile and sometimes it will turn after I plug in outlet, Other times it takes a few hours for TV to turn back on. ...
MY TV KEPT GETTING WORSE EACH DAY ALSO. BUY A CAN OF SPRAY AIR WITH THE EXTENSION SPRAY TUBE. WHEN YOU GET THE TV RUNNING SPRAY THROUGH THE HOLES IN THE BACK RIGHT ONTO THE FAN BLADES OF BOTH FANS. THE DUST WILL FLY OFF THE BLADES. A VACUMM HOSE WILL HELP PULL OUT THE DUST. ALSO SRAY THE POWER SUPPLY BOARD FOR DUST. I APPEARS THE FANS SLOW DOWN WITH DIRT ON THEM AND THE EXTRA HEAT BUILD UP JUST AFTER THE TV IS SHUT DOWN IS CAUSING THE POWER SUPPLY TO BE IN A SHUT DOWN MODE WHEN POWERED UP THE NEXT TIME. BEEN TWO WEEKS NOW AND WORKS PERFECTLY NOW AGAIN.
Dec 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
PC SHUT down
three things i find to cause this,
one, the power supply is bad,
two, the power connector is lose or not push in
three, the heat sink on the processor has come off. This will cause the cpu to over heat and self shut off.
to test the power supply, pull the connector off the mother board and short the green wire to any black wire with a paper clip, this will switch on the power and see if it stays on.
if you need to replace it, you cannot use a regular atx power supply. E machines have a different pin out.
Aug 12, 2009 | Dell E151FPp 15" Flat Panel LCD Monitor
Wii just shuts down
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-1
Jul 18, 2009 | Nintendo Wii Console
Wii over heating
get a cooling station
Aug 07, 2008 | Nintendo Wii Console
KV7-V power supply
follow the power cable from the PSU to the motherboard and see if the 21 connection has melted to the motherboard. You are better getting a 500W silent type, but it depends on the peripherals you have installed, try www.ebuyer.com for various makes.
Oct 09, 2007 | Abit KV7-V Motherboard
Nintendo Wii Console Logo
56 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
