Question about Furuno NavNet 3D Hub
MY NAVNET 3D MFD12 GPS SCREEN IS SPINNING IN CIRCLES??????
  • 1 more comment
  • Kevin Gens Sep 01, 2010
    What software version do you have? When the display is turned on you will see a number in the lower portion on the warning screen. That is the software level.
  • ericllindsay Sep 02, 2010
    Hey Kkmog1404 the software version on the furuno unit i believe is 1950055-02.05 Thanks for your input!! The screen went haywire one weekend in the bahamas and continued all the way back home then for the next three days or so it would do it (spin) every time you turned it on. So we called the installer and they came out and of course it wouldnt do it anymore and they had no idea what would cause it to do that so they contacted furuno and they had never seen the problem either. so they updated the software and then the port motor blew up 2 days later and its been in the shop getting repowered eversince. so we really havent had a chance to see if it works now??!?! They have been out three times before for the gps signal going out and the 1st time cleaned the gps contacts and the 2nd time they ended up replacing the gps antena they said it was full of water and the third time they replaced the gps antena and the cable??? i have never seen so many problems with electronics before water in a brand new gps antena??? they asked if we sprayed the hose on it directly. i said yeah sure we did thats what we do for fun is see how many times we can shoot the hose at the gps antena. anyway thanks for wahever info you can pass on this way.
    VERSION 1950055-02.05
  • 64 Answers
The GPS antennas are sealed so I don't see why they would ask if you sprayed the hose at it...it won't matter. I did some fishing this past year in the Keys on a boat with the same system you have and I scrubbed the GPS antenna and sprayed it directly with water and it did not have water intrusion.
Do you know which GPS antenna you have? Also, do you have any other equipment that may be interfaced to the MFD? I am assuming that you have a NMEA2000 antenna (model GP330B). If this is the case I would first check the NMEA2000 backbone. If you don't know what that is look for some cables all plugging together via Tees. there will be 2 cables per tee and the tees plug together. Make sure that there is a terminator at the end of the tee block. If you have the NMEA2000 antenna the other terminator should be in the antenna itself.
Do you have the engine interface wired to the MFD? If so, unhook that wire. I have seen some really weird things happen if the engines are sending some information back to the display.
We have installed many of these systems and the only failures I have seen are people damaging the radar antennas. The systems we have installed have been bulletproof for the most part.
Posted on Sep 02, 2010
Nav net 3 fish finder screen is is not showing the bottom
The NavNet 3D has a sonar module such as DFF1 or DFF3 or DFF1UHD. This is the fishfinder and may lack power. Also, your transducer could be failed with this indication.
Dec 28, 2012 | Furuno NavNet 3D Hub
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
How do I remove the "toolbar" from the top of the screen on my furuno NavNet Vx2?
go to toolbar with controller, and push clear key. just it.. but when you restart your system, it appears again. if you wanna lose it anytime, you must do it inside the General Setup.
thanks..
Dec 21, 2012 | Furuno NavNet vx2 1920C GPS Receiver
Furuno MFD12 Navet freezing and needing to be rebooted
i faced to this problem many times, you can upgrade your system version to latest one. it will be ok.
thanks..
furuno technician
Ozgur Calik
Sep 09, 2012 | Furuno NavNet vx2 1724C GPS Receiver
Connecting power inside Furuno DRS4D
polarity is maked on the shield, on a sticker #1 is positive, #2 negative BTW, this is 48V DC (not 12V) supplied from a MFD8, MFD12, or MFDBB only.
Jul 05, 2009 | Furuno Navnet 1964CBB/NT vx2 Radar C Map...
Adapt 997c si gps to navnet furuno sounder
no can do you must have a Furuno GPS or a GPS with NMEA 0183 output. you could get that from the Hummingbird display but not straight from the antenna
Feb 27, 2009 | Furuno NavNet vx2 1920C GPS Receiver
I would like to purchase a full Furano Navnet 3D system with for my 42' sailboat now in production. It does not have hydraulic steering though. Is there a hydraulic linear drive compatible withe Furuno...
No, you will use the appropriate Simrad Drive unit such as an HLD350. It comes in long and short throw and split versions, and dual ram versions. Better to discuss on the phone probably. 847-746-0100 or email support@technicalamrine.com
Aug 09, 2008 | Furuno NavNet vx2 1920C GPS Receiver
I can not seem to get a simrad ap 20 to recognize the nmea connection from the navnet vx2
you will have to designate which sentences to send to the AP20 from the navnet under port options. also make sure the AP20 is set to read the correct port to accept the information such as gps1 or 2 or nav1 or nav2
Jun 29, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno navnet 1723 C
go into installation mode (hold menu during power on) find radar setup, go to next page, do heading alignment. also tune video, your unit was reset!
Jun 09, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno NavNet 3D Hub Logo
169 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
David Burbee
David Burbee
Colin Stickland
Colin Stickland
Are you a Furuno Boating Expert? Answer questions, earn points and help others
