Question about Toshiba 13A23 13" TV
My Toshiba television Model 13A23 is not working. There is no horizontal signal from Video Chroma Ic but the B+ voltage is present. Can you tell what can be cause of this problem?
  • 70 Answers
Pls check the jungle IC it genarate the horizontal signal croma ic used that signal may be failure in horizontal oscllator section
Posted on Aug 27, 2010
No picture, just coloured stripes then white screen
defective video/chroma section,test defective buffer transistor,leaky capacitors and open resistor.test the chroma ic afterward if gives color signal(dc.volts refer to diagram,systems voltages)
Jan 26, 2014 | Televison & Video
Rca xl100 tv
There is two causes to this fault. The first one is the absence of voltage to video output transistors. Check the input voltage, it should be around 290VDC, that supplies the collector terminal to each video output transistors. The second reason is failure of color matrix section circuit. This circuit is within the Chroma IC. If this is the case, the IC should be replaced. If you're not familier with electronics, it is best to contact any service technician.
May 25, 2013 | Televison & Video
When we try to turn on the tv (toshiba model 32A43) it makes the sound of turning on then off and the screen stays black and a red light by the power button keeps binking
You're either losing high voltage or power supply is not producing the horizontal drive signal, Check for 130v on the collector of the horizontal output transistor, if you're missing your voltage, you have a power supply problem. If voltage is too high you have something open in the power supply such as a low value resistor. If its low, something is shorted in power supply, possibly voltage regulator ic.
Jul 31, 2011 | Toshiba 32A43 32" TV
Please help me, i'm repairing 14" old model television.. it don't have brand name but it is using 47C434N-R201 system, TA8680N video chroma IC, 30115 regulator, my problem is it don't have...
Good day!
Try to check the base of the horizontal output if have a signal from the chroma or jungle i.c it should have 5-7vac to trigger the high voltage.If no voltage try to hang it and check again if the voltage appear while you hang it,your ply-back got partially defects replace it with the same type and ratings.
Next,if you already hang the base of h-out and still no voltage on it and the chroma i.c is new.Trace the line from the base of h-out to the chroma/jungle i.c.Test the parts that pass through that line such as open/change value resistors.
I hope this solution will be helpful.Thank you I'm very glad to share my idea.Good luck.
Apr 21, 2011 | Mitsubishi Televison & Video
SONY KV-M2180D FLASHING 6 TIMES
hi,
it flashes 6 time because its horizontal oscillator have some problem. can be caused by the malfunction of main chroma ic. it generates all the sync signals. or the horizontal driver transistor or horizontal driver transformer. also check the collector voltage of the horizontal driver transistor. also check the frequency at the base it should be 15625 Hz. check the power supply voltage of main ic also .
ok .
Dec 21, 2010 | Televison & Video
Red light flashing on tv and tv won't switch on
sound like chroma ic problem. but you not present model# so i can"t tell you what correct# for it. if you know about what is chroma ic, replace it. if not take it to prof shop do it. good luck!
Jan 05, 2010 | Samsung TXM3297HF 32" TV
No color.
Hello strata_rocks,
This denotes a possible malfunction of the chroma (color) circuits in your TV. You will need to check and see if your chroma signal is being generated at the output of the video processor IC. In addition you want to check the video signal to make sure that the color burst signal is present once the video signal is modulated from the IF input section of the video processor.
These are start off points for your troubleshooting. If you do not have a background in electronics, you have two options, the first is to replace the video board, the second option is to have a qualified TV repair person work on your television and change the board out, after troubleshooting the problem.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
NO PICTURE BUT HAS SOUND
Hiii.....
Ekisa...I see the TB1226xx likes chip/ic for Video Chroma and syc signal processor NTSC/PAL?SECAM color TV ( by Toshiba )....I can give you the Datasheet by e-mail...
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Mar 21, 2008 | Televison & Video
ABOUT PHILIPS TELEVISION
The 8V at pin 36 won't show unless there is oscillation, the primary voltage pin is pin 10, 8v. Don't mind me asking, you have checked the B+, right? Because the blinking LED is often because of power supply problems. And if that's okay, desolder the horizontal driver output legs and connect an LED to find if it is oscillating, if it does, forget the ic part and move on with the FBT and things. Good luck.
Jan 31, 2008 | Televison & Video
No video
from voltage given by you states that rgb output voltage is more than normal & drive is only .2 volt which is abnormal means signal is not coming from chroma ic. so check for loose connection in chroma ic or connector loose. same time your drive voltage abnormal is due to signal not coming so no voltage drop & more voltage. also check for crt base loose. hope this will help. good luck.
Oct 01, 2007 | Televison & Video
Toshiba 13A23 13" TV Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
