Question about Canon CanoScan 8600F Flatbed Scanner
Will not scan photos, only slides
I have scanned many photos with the canoscan 8600F with success. Later I took out the protective back, put in the slide holder and scanned slides successfully also. However, when I put back the protective back and took out the slide holder, and tried to do photo scanning again it would not work.
  • Anonymous Dec 15, 2008
    I place an image in the scanner and it comes up white
    Scholar:
  • 111 Answers
Where are you scanning from? Do you get an error? If scanning from Toolbox, check the box that says to use ScanGear or use the Scanner driver. Then make sure it is not set for Film as the select source.
Posted on May 09, 2008
Scan from in to Microsoft Word
To be able to do that without problems you have to have installed the whole program for the scanner..I mean the driver and the software to manage it ..This can be downloaded from canon support site in case you do not have it on a disk ...or in the computer ..
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_8600f#DriversAndSoftware
here is the link where you can download the canoscan toolbox..which is teh software I was talking about ..
So , the procedure is to initiate the scanning from the toolbox in the computer ..and during the wizard ..select the preferences to scan document ..and not photo ..This will probably give you the possibility to select the program to be scanned into ..or will scan in word by default..remember to select the option to scan document ..and not picture..otherwise will scan as a photo and will end up with a jpeg of gif file ..
Please do not hesitate to ask more questions in a comment if you have something you did not understood..and please rate my answer cause it affects my work here ..
Oct 31, 2011 | Canon CanoScan 8600F Flatbed Scanner
Inability to copy film to pictures
When you were scanning, did you set the scan selection to scan negatives ?
Jan 20, 2008 | Canon CanoScan 8600F Flatbed Scanner
Scans are taking a long time to scan.
1) Your scanning image resolution may be too higher set 300 dpi / 400 dpi / 600 dpi. Scanning now fast.... not ok look step 2
2) Re-Install Scanner driver / down load new driver. not ok look step 3
2) Replace USB cable.
Mar 28, 2011 | Canon CanoScan 8600F Flatbed Scanner
I have a CanoScan 8600F. When I want to scan I get the not enough space on the target disk
This seems to happen quite often with the Canon scanners. If you know you have enough space on your hard drive, open the CanoScan Toolbox, then click on Settings and change the folder where the temporary files are stored to another folder of your choice, or create a new one in your documents.
Dec 06, 2010 | Canon CanoScan 8600F Flatbed Scanner
Re: Canon 8600f scanner. How do I get this to file in jpg rather than pdf? How do I control scanned picture size? I get a full page (8.5" x 11.0") with a real size scan on top. Peter
My cannon 8600F was ori=ginally connected to my old laptop & I could scan any document and save as a jpeg file. This was with Windows XP Prof.
Mow my new laptop has Windows 7 & I downloaded Primo from the web. But now I am not able to scan a picture and save as Jpeg file.
Please help.
Aug 07, 2010 | Canon CanoScan 8600F Flatbed Scanner
Receive "cannot scan because the original may not be set correct.
Is your Scanner locked ? If yes then you will see there's a solid plastic backing on the inside of the lid that needed to be removed. Also remove all protective plastic too.
Sep 18, 2009 | Canon CanoScan 8600F Flatbed Scanner
Won't scan - says not enough disk space.
I had the same problem. Solved it by going into the "CanoScan Toolbox" - "Settings" - and pressing the "Defaults" button in that panel - and then "OK" button. Afterwards everything worked fine. Hope this helps you.
Dec 18, 2008 | Canon CanoScan 8600F Flatbed Scanner
Fi=5120c conflict with another scanner
Kindly reply back immediately once you get my email.
Nov 04, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Cannot scan film and slides
Check the cable that connects to the lid of the scanner. If it is disconnected, you won't get the Film options.
Jan 21, 2008 | Canon CanoScan 8600F Flatbed Scanner
Canon CanoScan  8600F Flatbed Scanner Logo
290 people viewed this question
old marine
old marine
