Question about Refrigerators
I have a Sub Zero 632 Dual Refrigeration System. The fridge side is not getting cold and the unit condensor fan runs continuously. The vacuum condensor light comes back on within 24 hours of cleaning the coil. Both circulation fans are working. There was a glob of ice on the pipe and sensor on the upper left corner of the fridge coil which I removed and after 24 hours the fridge got down to the mid 40's which is better than the low 50's it was running at previously. Suggestions?
  • brad653 Aug 24, 2010
    Is this website a scam?
    I ask a question and I get excuses....and this is the second time it has happened.
    Sergeant:
    Champion:
  • 311 Answers
This has a sealed system issue- you need a servicer to make the repair. There is nothing you can do yourself.
Posted on Aug 25, 2010
My 632 is flashing EC 40. What is the problem?
Here's a list of all error codes for the 600-series Sub-Zeros.
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
EC40 = Excessive Freezer Compressor Run
Mar 24, 2011 | Sub-Zero 632 / S
Sub zero 632
3C on the fridge side
-18C on the freezer side
Sub-zero repair in Orange County, CA
Jan 30, 2010 | Sub-Zero 632 / S
Subzero 680 - vacuum condensor message won't go away.
You can reset it by turning the unit on and off or if you have a door alarm button hold that for 30 seconds and that should clear the fault code.
Aug 16, 2009 | Sub-Zero 632 / S
I have a 7 year old sub zero 632. The
The sub zeros I have worked on have a compressor for each side. Is your fan blowing. You may have a defrost timer or heater. Possible low on gas but thats not very likely the sub zeros are made very well. Check to see if fan is blowing. Check condensor coils on top to see if they are clean. Check to see if your condensor fan is blowing. These are just possoble problem you can check if every thing looks good. Call a service tech ask for free estimate on repairs. Rus
Jul 06, 2009 | Sub-Zero 632 / S
Subzero 632 cycles from 37 to 50 degrees
few things to check... condenser coil clean. dirty condenser fluctuate temp. clean condenser. evap fan motor work? open the fridge. press the switch. heard the fan? feel the frame around the fridge an freezer is hot? or cold? cold ok. hot dirty condenser coils OR condenser fan motor. or seal system problem. call a tech>.. good luck... LEAVE YOU COMMENT IF IT WAS GOOD FOR YOU... thanks
Mar 07, 2009 | Sub-Zero 632 / S
Subzero 561 Fridge side works, Freezer side working fine
Sounds like a cold control. It is located behind the panel and can be ohmed out to check for proper operation. You need to remove the light shield then after the shelves have been taken out remove the two screws that hold the fan shroud in place. This will allow back panel to come for so you can check the cold control. It should read as a short in all positions except off when the cap tubes have come to ambient temp. If you get the back off and see ice on only a small portion of the evaporator you have a sealed system problem and need a qualified technician.
Nov 24, 2008 | Sub-Zero 685/S Stainless Steel Side by...
Sub-Zero 532 not cooling
Simple think I guess - just pull down a little a plastic fan blade on motor shift it will produce a powerful air flow. Fan blade should sit pretty close to the shift end. ;)
_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jun 11, 2008 | Sub-Zero 632 / S
Sub zero side by side
evaporator leaks freon, made a video on how to replace it
Oct 09, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
