Question about Maytag MSD2656G Side by Side Refrigerator
Maytag side by side
My freezer is working fine. But I am unable to get the refrigerator section to cool. Making adjustments to the sliding temperature setting levers does not help. Can it be "stuck" in the defroft cycle, or perhaps the thermostat "coil" has gone bad. Compressor seems to be fine. And the freezer is plenty cold. I am leaning towards replacing the thermostat, but don't know if that is necessary with the freezer cooling as it should?
  • 63 Answers
The controls should be set half way, If you want a colder food compartment turn the frezzor control to a lower setting. You may have a defrost problem though see if you have a snow build up on back panel inside the frezzor if it does you have a defrost problem it could be a defrost timer. heater. limiter. evap fan.
Posted on Jun 10, 2008
  • 45 Answers
All the cold air is made in the frezzer section then blown to the refrig section, the frzzer needs tobe -5 or 0 degrees F, also post model and serial number
alot of time people think if it freezes water it is cold but that happens at 32 F
Posted on May 16, 2008
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
The freezer is working fine but the refrigerator is at room temperature.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Maytag 19.8 Cu. Ft. Side-by-Side...
Maytag side by side, freezer working fine, refrigerator not cooling.
If your freezer side is capable of making ice, and that ice is dry and remains so,
the only issue you have is insufficient airflow to the reefer box section from the freezer.
The refrigerator section is 100% reliant upon the frezers side for all of its cold air.
The refer box has no evaportator of its own, There are 2 settings or dials.
One is the temperature thermostat, it actually controls the compresssor motors cycling,
thus the desired ice box temperature as well, it often says 1-10 and off as well, the reamaining setting, the one that cannot turn the compressor motor either off nor on is a damper door controller, that modulates the freezers airflow into the reefers box!This is where the problems occur, when one notices the reefers box is warm, they max both settings,which seems logical , and is for the thermostat dials setting.Where the major counter intuitive reality exists is the flapper dooors setting will say Colder and Warmer!!Colder of course!! right?? No, it actually means and usually does say, Colder Freezer!!not Colder Reefer! so you MAX or RAISE the thermostat, thats ok to do.But maxing or raising the other setting is just starving the reefer box section from sufficient cold air flow to maintain adequate temps.I have gone to hundreds of identical calls, Freezers ok, but Reefers warm! If the freezers making ice and the ice is dry, there is no problem with the refrigeration system, its airflow.when defrost timers or heaters fail the symptoms may be as yours, however the freezer will slowly warm in another day or so. But if the freezers making ice for days and never getting wet theres an airflow issue period, you may need to remove the back wall panel in the freeezer to see the coils condition , is it iced up or blocking airflow with icing/ is the ducting open between the freezer and reefer boxes?setting both dials to the midway setting should work fine. the condenser coils may be dirty/dusty too, is the cardboard backing still in place on back? it needs to be there intact.
is there product inside the reefer box? if not add 3 gallons of water.
Dec 27, 2010 | Maytag MSD2355HES Side by Side...
Refrigerator less than two months old. Freezer side fine refrigerator side stopped working altogether. All food ruined. Who should I contact. purchased from Home Depot.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
Add a comment
Dec 24, 2010 | Maytag Refrigerators
Not making a lot of ice and water not cool have change filter and filter still on
your freezer is probably too warm- you need to adjust the freezer temperature
Sep 17, 2010 | Maytag 21.6 Cu. Ft. Counter-Depth...
Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Jun 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer working, not making ice; refrigerator not cooling
Look for excessive frost build up in the freezer, there may be a problem with the defrost cycle.
Dec 29, 2008 | Maytag MSD2756G Side by Side Refrigerator
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
Maytag MSD2657HES Refrigerator Side by Side
The air that cools the refrigerator section comes from the freezer. The refrigerator temperature control controls the run cycle. You may have to replace or have the thermostat replaced. The temperature control has failed.
Jul 29, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator side of my side by side to warm
Check the back wall of the freezer section for signs of frost buildup. Your problem could be caused by a frozen evaporator coil in the freezer section. After making your check come back and give the model number of your Maytag .
Jul 03, 2008 | Maytag Refrigerators
Maytag MSD2656G Side by Side Refrigerator Logo
129 people viewed this question
Top Maytag Refrigerators Experts
Richard Roth
Richard Roth
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
