Question about Bowflex Treadclimber
My new treadclimber 5000 does not accurately record steps taken, though it does show mileage. How do I get it to record steps taken?
    Champion:
  • 218 Answers
You will need to remove the plastic covers and locate the step sensor. This will be close to one of the arms. There is a magnet mounted to the arm and the sensor reads every time the magnet passes by. The sensor should be a credit cards width from the magnet. If it is and it still isn't reading you may need to replace it. You can call the bowflex company and they can send you one.
Posted on Aug 25, 2010
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
What is the problem with treadclimber malfunction 84 u 1.1?
Try to run the treadmill @ 10kph. W/o using it. If the problem comes up. The problem is only the speed sensor..
and if the treadmill is in normal condition with out someone using it. @ 10kph. The problem is only lack of lubrication. You need to lubricate the treadmill before you using it. To prevent the motor from breakdown.
Jun 09, 2014 | Bowflex Treadclimber
HOW TO CHANGE MY TREADCLIMBER TC10 WALKING BELTS
Bowflex has a service manual for the TC10 that includes walking belt replacement instructions, If you call customer service they should be able to email the whole manual or just the belt replacement steps.
May 07, 2013 | Bowflex TC1000 Treadclimber
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
My machine is making a grinding sound (medal to medal) when i use the machine. if i lock it and only use treadmilll it is ok. it seams to happen more and more. i really grinds if i stand on step offs....
You'll need inspect the movable areas of your unit by hand something may have come loose or see if their is any excessive lateral play could be worn or cracked bushings. Have some else help you by stepping off on either side to see where the sound more prominent. Unfortunately it a process of elimination good luck!
May 29, 2010 | Bowflex Treadclimber
My bowflex treadclimber goes slow/fast/slow again and stops. It then shows an E1 on the display. What can I do to fix this? I have no directions for trouble shooting. Also, should I be able to speed...
The speed sensor is not connected correctly. There should be a jumper wire that runs from the speed sensor over to a harness by the control board on the other side of the machine. There may be a second jumper wire connected to nothing, only used in the 3000/5000 models. There is also a wire that comes from inside the treadles that isn't used on the 1000. The current assembly manual available from bowflex online seems to explain it better.
Oct 26, 2009 | Bowflex TC1000 Treadclimber
After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Jul 11, 2009 | Bowflex Treadclimber
Bowflex Treadclimber Logo
143 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
