Question about Dryers
I have a Whirlpool gas dryer model #WGD5530SQ0 that will not start when the button is pushed, It has power, the light is on inside. Whats my problem?
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Whirlpool Gold dryer its digitial. it turns on lights on but you push the start button and it won't start
a bad push start switch, a bad door switch, a bad or blown thermal shut off fuse due to over heating? whats ur venting like?
Mar 18, 2015 | Whirlpool Dryers
Whirlpool cabrio dryer has power but won't start
You may have a burnt out terminal block or start switch.
May 12, 2012 | Whirlpool WGD6400S Gas Dryer
My GGQ 9800 gas dryer won't start. It was working
Things to check first on a no start dryer.
Check for power at outlet.
Inspect power cord.
When you try to turn it on do you hear anything?
Check the door switch(does it click when pressed in?)
The next item to check and most likely replace on a completely dead dryer with power and a good door switch would be the thermal fuse located inside the cabinet.
Please let me know if I can help with anything else
Apr 08, 2010 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Feb 04, 2010 | Dryers
I have a Whirlpool gas dryer LGQ7030K..the dryer does not turn on when start button is pushed.
If you open your dryer and the inside light isn't on - double check your breakers.
Also make sure the timer knob is set properly to a setting with minutes left.
Dec 06, 2009 | Whirlpool LGQ7030KQ Gas Dryer
My whirlpool dryer model- ygew 9250 pwo will not power up when I control on button. If I push the power on button and the pause button at the same time some times it will start and run and sometimes I may...
When this problem occurs are the small lights on very dim? If so I would turn off the power and remove the top off the dryer. Then re-seat the 4 ribbon cables on the display board. Alot of people replace the front panel or control boards when the problem really is the ribbon cables. If the LED's are not lit dim then you may need to replace one of the two boards.
Jul 24, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Supreme Dryer will Not Start
I have a whirpool heavy duty dryer that is not working. When I push the button to start the dryer it only roars, and the drum will not move.
Dec 30, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
96 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
