Question about HP 1730 LCD Monitor
I have a (HP L1730) flat panel monitor that im trying to use with my HP Compaq 6910p Laptop. When I power on the monitor,there is a quick 1 second flash of my desktop on the screen,then it goes to a black screen. When I power the monitor off then turn it back on, it displays going to sleep then shuts off to a black screen and the green power light stay lit. I have check connections,changed my display setting to multiple monitors,downloaded drive whiz and still no luck. Pleas any help is appreciated. Thanks Garvin
  • 11,361 Answers
Does it do the same when it is hooked up to desk top PC?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a rel='nofollow' href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Posted on Aug 25, 2010
My HP L1730 Model PE1238 17 inch lcd monitor wont switch on. it makes a sound every couple seconds. it sounds like it does when its coming on but its cut short fix please ?
How to repair HP Pavilion f1703 lcd monitor - YouTube
? 5:48
https://www.youtube.com/watch?v=rFXyIMAq64o
Jul 11, 2010 - Uploaded by z28r2fast4u
How to repair HP Pavilion f1703 lcd monitor. ... 17:38. HP L1750LCD monitor repair - Also applies to ...
HP W2207h LCD MONITOR-HOW TO TURN OFF OSD ...
h30434.www3.hp.com > ... > Video/Touch
Solved: MY EXTERNAL, HP W2207h LCD FLAT SCREEN MONITOR OPERATES FINE WITH ... HP ENVY 17t Touch,i7-5500u,16GB, 256 GB SSD (on loan)Missing: l1730 ‎pe1238
Using and Adjusting Your Monitor - HP Customer Support
Dec 25, 2015 | HP Computers & Internet
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
Hp L1730 (P9625A) tiene manchas en el display
Just press your finger anywhere on the screen and it will turn darker around that spot.
You obviously warped the outside lid of your laptop. See if you can take the lid and the LCD apart and straighten the lid to relief the LCD-pressure from behind (literally...)
Jul 27, 2012 | HP L1730A (Carbonite, Silver) 17 in. Flat...
My hp compaq 6910p laptop not on adapter is ok **** i plug in laptop no power on no any light on
Unplug adapter using cheap multimeter, check for voltage on the Plug the goes to laptop.. the plug should be producing 13+ volts ( not sure exactly of Spec, but it is located on the power pack itself. )
Your problem sounds to me like your power supply is shorting out .
Alternative problem is the charge circuit on the mainboard may need to be serviced. ( commonly replacing mainboard- some facilites can repair )
Jan 12, 2012 | HP Compaq 6910p Notebook PC PC Notebook
Where dos jumper located on compaq 6910p and how can i remove bios password on 6910p
Most "laptop" computer do *NOT* have a jumper that can be used to bypass a BIOS password.
This is DELIBERATELY done, so that a thief in possession of your laptop cannot bypass your password, and thus cannot use your stolen laptop.
Find your original bill-of-sale, to prove ownership, and telephone HP/Compaq, and ask for Technical Supoprt in resetting the BIOS password.
Jun 20, 2011 | SIB SATA 250GB for HP/Compaq 6910P NW8440...
My laptop hp have problem monitor giving mesage ''monitor going to sleep''
hi you will need to reinstall the vga of the system to enable it not to write that again
May 19, 2010 | Computers & Internet
I have an hp compaq 6910p lap top which a friend has password it in the setup and i am finding it difficult to use it. what should i do to clear the password in the setup. eric
You can try to open your computer and disconnect the cmos battery for 10 minutes. this is a small battery that keep the changes saved. When you disconnect it, All changes will be lost. So also the password. This is the sequence:
1: take off the accu
2: open up the laptop
3: take the cmos (small flat round battery) out
4: Wait 10 minutes
5: plug in you adapter and boot the laptop
6: when you see that the password is gone, power off the laptop
7: plug everything back in.
8: You are done! :)
Apr 20, 2010 | HP Configurable- HP Compaq 6910p Notebook...
How to replace the Keyboard?
if you are not sound on technical ground its better to be done by the technician
Oct 17, 2008 | HP Compaq 6910p Notebook
HP 1730 LCD Monitor Logo
188 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
