Question about Intex 1 "a" Filter Cartridge Pool Pump Replacement Part ()
I have a 15x48 intex metal frame pool with a 637 pump that uses A cartridges. I have cleaned out the filter and the skimmer and after hooking everything back up and bleeding air out of the lines I plugged the pump back up and it looks like it's blowing white stuff in the pool..Which I think is air..I can unplug pump and bleed the lines again and plug it back up and it won't do it at first. But after about 3 minutes it starts it up again...It will make the water foamy. What can I do? I have cleaned over and done everything just like I am supposed to..It's just started doing this.. I have had my pool about 3 months and this is the first time I have had this kind of trouble..Please help!
  • 366 Answers
If the system is consistently blowing air into the pool in large quantity, you most likely have a suction side leak that is allowing the pump to **** in air and return it back to the pool. try shutting the system off and inspect the suction side for any water leaks, that should lead you to any air leaks on the suction side. try turning the pump on and off a few times to catch any water spurting out of the suction side. Also, make sure the skimmer is now enough to not create a vortex and **** in air as well. Hope this helps.
Posted on Aug 26, 2010
How low do you take the water when closing
Down below the wall fittings, and the skimmer so you can drain the lines. Also be sure you remove the drain plugs from the pump and filter.
Sep 05, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Filter assembly Intex 15X48
The lower hole is for suction and the higher hole is for return.
The Pool Tech
Jul 07, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Skimmer and Vacuum set-up question
Here is a link to Intex website for the manuals and videos. Intex Pool
Jun 25, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Where does the skimmer sit on an intex metal frame pool
i have mine sitting about a foot to the right of the intake on the pool, that way it keeps a clear line from the skimmer to the intake to the pump/filter to the outlet
May 30, 2010 | Intex "" Metal Frame Pool Set (56998e)...
How much salt to start with a 15ft round pool
Assuming you have the Intex salt water system and the easy set pool, here's what the manual says:
15x33" - 65 pounds (80 for metal frame)
15x36 - 65 pounds (100 for metal frame)
15x42 - 80 pounds (110 for metal frame)
15x48 - 95 pounds (N/A for metal frame)
hope this helps!
May 28, 2010 | Intex Automatic Salt Water System for ...
How do you fix a leak to a 15x48 swimming pool without emptying all the water? it's a small leak on a seam near the ground.pool has been up a week & no leak, until tonight?
They make underwater patch kits that are very simple to use. You cut a patch and apply glue, fold the patch in half with the glue faceing in. take it to the leak and slowley unfold against the hole. smooth out and make sure edges are sealed down. Keep pressure on the patch as instructed on package. Then let cure. Good luck.
May 28, 2010 | Intex Ultra Metal Frame Pool w/ Upgraded...
Pump and skimmer instructions on how to
Direction of flow is FROM the skimmer to the pump and back to the jet. Its easy enough to determine which hose is the "jet" hose and which is the suction hose. Put both into the water, or in a bucket and turn on the pump, find the one that is shooting out water, that's the jet hose. On these systems, filter replacement and cleaning is annoyingly frequent if you want it to work even remotely efficient.
Apr 11, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
I have the 15' X 42'intex metal frame. Pool and
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex 1  "a" Filter Cartridge Pool Pump Replacement Part () Logo
150 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
