Question about Refrigerators
Cannot get fridge to ignite or work off gas - Refrigerators
  • 828 Answers
Try lighting the burner manually from the back. Electric must be all the way to off before you can start the gas burner. One locks out the other. If you can light it from the back you have an ignition problem.
Posted on May 05, 2008
Caravan fridge wont ignite when on gas
does fridge work on 12 volt? If yes, 1 check and make sure you have 'good' gas. Next you can check the orvice/ignition area for any forgien matter, cobb web/spider webs must be removed. You can blow out that area with nan air hose. wear safety glasses!!! follow instruction for lighting. If you still do not have any flame you mave have a bad pilot valve.
Feb 18, 2012 | Electrolux Refrigerators
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
Camper fridge does not work on gas.
right where the gas comes out there is an elect igniter do you see or here it clicking some times carbon buildup causes it to ground out inproperly sometimes the bracket gets rusty the bracket needs to be able to fire a spark directly twards the jet good luck
Apr 12, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Fridge will not work on gas
If you're sure the gas is igniting and making heat, you may have lost your refrigerant. It probably is ammonia, which smells very strong. Check your dealer for someone who can check it out.
Apr 27, 2009 | Refrigerators
Camper fridge ignites and runs on gas then fails
I beleive the thermocouple is faulty, this allows gas to flow once the flame is lit, but will also close the valve if faulty. Rateme
Mar 11, 2009 | Electrolux Refrigerators
Dometic rm2852 does not run on gas
Sounds like your ignitor porcelain is cracked. Yes there is a miliamp signal sent to the circuit board to stop the ingnitor from arcing
Dec 30, 2008 | Dometic RM2852 Refrigerator
FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
Aug 11, 2008 | Dometic RM2652 Refrigerator
Motorcaravan fridge auto-igniter continues to flash even when fridge has lit but the gas flame ,visible through small glass in the inside rear of the fridge remains constant.Usually a do-it-myselfer i am...
Yes the problem has been solved by cleaning jet and repositioning thermo-couple so that it is well into the flame.It would therefore appear that the combination of a partially blocked gas jet and a badly aligned thermo-couple triggered the auto-igniter .
Thanks for your interest,.......I am afraid that at my age now help has to come free of charge.A new auto-igniter would have been £69 and a thermo-couple £35.A new jet was a reasonable £6...........
Regards Iain edwards g4wrk@talktalk.net
Apr 29, 2008 | Electrolux Refrigerators
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
