Question about Garmin nuvi 1300 Car GPS Receiver
Can i get mph on my nuvi 1300 - Garmin nuvi 1300 Car GPS Receiver
Tip
Garmin Nuvi 1300 Manual Download
Download Garmin Nuvi 1300 Manual
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Have you lost your Owner's Manual for your Garmin Nuvi 1300 GPS?
Would you like a digital copy of the Garmin Nuvi 1300 Users Guide for easy searching of terms and quick reference?
The Nuvi 1300 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
on May 13, 2010 | GPS
1300 nuvi screen comes up loading maps and stops
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
May 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
Tip
Download Garmin Nuvi 1300 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1300 GPS?
Would you like a digital copy of the Garmin Nuvi 1300 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1300 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1300 Favorites Backup and Restoration Procedure Models: Nuvi...
Would you like to back up a copy of your Garmin Nuvi 1300 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Nuvi 1300 squeal
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Jan 06, 2010 | Garmin nuvi 1300 Car GPS Receiver
Tip
Garmin Nuvi 1300 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
on May 13, 2010 | Garmin nuvi 1300 Car GPS Receiver
Tip
Garmin Nuvi 1300 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1300 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
Garmin nuvi 1300 Car GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
