Question about Altec Lansing ADA 885 Computer Speakers
I have an Altec Lansing ADA 885 subwoofer that will not work. The four speakers work though. I checked the fuse and it looks like it is ok...not burnt out.
  • 29 Answers
SOURCE: No sound
Check the connector that the speaker with the control is plugged in with, make sure that where it is connected to the sub woofer that in the connector , all of the pins are there, and that none are broken, also cdheck the sound cable, try switching it out for another : )
Posted on Nov 11, 2007
Benimur
  • 6966 Answers
SOURCE: Altec Lansing ADA 885
Thanks for posting direct. As you posted, the Sony XBR has only left & right (white/red) outputs whereas your Altec ADA has multiple INputs. This leaves us with no other option but to used just the green INput of the Altec as the black and the S/PDIF has nowhere to be connected to in the Sony.
You would need to use a phone stereo to RCA cable/connector as shown below. Additionally, you would have to set up your speakers as suggested here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 11, 2008
SOURCE: Altec Lansing ada885
Same issue showed up for me today very randomly...
HD comes on and off for no reason and sound cuts in and out. This fix worked for me:
1.Disconnect the left speaker from the sub woofer.
2.Take the 4 screws out on the bottom of the left speaker. (They are under the rubber matting you can just poke holes through it)
3. Remove the bottom plastic assembly from the speaker
4. Cut the 4 wires to the headset chip. Careful not to cut any others to the speakers themselves!
5. Unscrew and remove headset plug chip
6. Reassemble and plug left speaker back into sub woofer.
No more HD issues =)
Posted on May 01, 2009
rulds2008
  • 3866 Answers
SOURCE: altec lansing 885 drivers
Please try www.driverguide.com this place has a huge databse full of drivers for old to new, I hope this helps as I am awaiting a good rate-ing- thanks
Posted on May 03, 2009
edwinmeyer
  • 57 Answers
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 22, 2009
Dp/n 08506p drivers
I have ALTEC LANSING DP/N 08506P speakers om my Windows 7 PC. The left speaker works fine but no sound from the right speaker. I "think" this is a rather recent event. Can you help?
May 24, 2014 | Altec Lansing ADA 885 Computer Speakers
Chep203205 audio jack board can ido without this board and just use the subwoofer
You would have to open the cabinet to gain access to the subwoofer terminals.
Nov 10, 2013 | Altec Lansing ADA 885 Computer Speakers
No sound from subwoofer
If your subwoofer does not work on your altec lansing speakers,
more than likely you blew the subwoofer amplifier board.
I have an ADA-885 system and bought it brand new back in
November 2000 and has been flawlessly operating great up
until this past month when my subwoofer went out but my
"satellite" speakers kept working. After disassembling the
subwoofer box I first noticed that the subwoofer amplifier
board is seperate from the rest of the grouped boards for
the dolby and satellite speakers. The subwoofer box is
designed to use the air from the subwoofer to actually
cool the amplifier boards inside the unit, great feature
until your subwoofer goes out, that is when your main
amp will more than likely fail soon after the sub amp
fails, as it uses the air from the subwoofer to keep the
amps cool. I know this might be an older post but
hopefully I can put it in the right category to hopefully
be able to help someone out in the future.
You can test the ohms of the speaker with a multi
tester. It's a dual voice coil speaker, 6 ohms each.
Well my system is broke and needs another
subwoofer amplifier board so if anybody reads
this and has this subwoofer, I need my sub amp
fixed ! or if you have the subwoofer unit maybe
and nothing else to go with it but the subwoofer
lights up, give me a jingle, I'd buy it from you !!
Jul 23, 2011 | Altec Lansing ADA 885 Computer Speakers
Altec lansing ada885 took a dose of 240V, burned fuse in place, replaced fuse, worked for about 2 hours, now nothing
Well is the new fuse still good or out again. if its good, then you probably fried the main board on the amplifier. These computer speakers do not handel big power serge's.
Mar 12, 2011 | Altec Lansing ADA 885 Computer Speakers
Hello, I have an Altes lansing ad-885 system and I have lost the cable that connects it to the pc, Where can I purchase a replacement. Thanks,
Altec Lansing ADA 885 connects with an SPDIF cable. Something like this should do the trick for you:
http://www.amazon.com/Toslink-Digital-SPDIF-Optical-Performance/dp/B001ENJ3ZA
Dec 22, 2010 | Altec Lansing ADA 885 Computer Speakers
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
Lights on Altec Lansing display flashing after power outage and have no sound,check drivers and they are active and okay,but unistalled and reinstalled just the same,no results;also replaced fuse on...
I had the same problem. It ended up being a short in one of the wires in the control board. It was actually pretty easy to fix once I located all the screws to take apart the speaker where the board is housed...
Nov 28, 2009 | Altec Lansing ADA 885 Computer Speakers
Subwoofer fuse 'holder' missing.
tape or solder a piece of metal across where the fuze and holder would go.
OR
go to radio shack, pick up a small cartridge style fuze holder and an appropriate replacement fuze. (if you dont have the original fuze, dont bother with this method) Open the box or case to gain access to the circuit board. solder a new holder to the contacts.
Be aware that I have no clue what the fuze holder on that particular model looks like.
May 27, 2009 | Altec Lansing ADA 885 Computer Speakers
How to hook my altec lansing speakers to my TV? and my laptop @ the same time
You can do this through a receiver (like a stereo receiver). Hook the tv up to line 1 and the computer up to line 2, then hook the stereo receiver output to the input of your subwoofer. Then shift the receiver from line 1 to line 2 (as easy as pressing a button on the front of the receiver) to hear either one through your speakers.
Nov 26, 2008 | Altec Lansing ADA 885 Computer Speakers
May 11, 2008 | Altec Lansing ADA 885 Computer Speakers
Altec Lansing ADA 885 Computer Speakers Logo
231 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
